1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Device support for a simple network ping
To: TechTalk EPICS <[email protected]>
Date: Wed, 02 Jul 2014 15:18:08 -0400
On 7/2/2014 12:09 PM, J. Lewis Muir wrote:
On 7/2/14, 10:58 AM, Phillip Sorensen wrote:
Hello all,
Does anyone out there have device support for issuing a ping to a
network device or a block of network devices.
Hi, Phil.
Why do you want this?
If you're trying to monitor whether a network device is up, there may
be some solutions out there, but they may or may not use an actual ICMP
echo request.  See this Tech-Talk thread:
   http://www.aps.anl.gov/epics/tech-talk/2014/msg00324.php
Lewis
The initial use is seeing that a network device such as an ethernet-to-serial converter or a network switch is on the network to give a "useful" alarm condition that points to directly to the problem instead of needing to know that if there is an error for some group of devices, it is probably this device. I might also want to disable all records use a device that is not working to reduce Alarms and error messages.
I am open to other suggestions, if you have them.
Phil
Device support for a simple network ping Phillip Sorensen
Re: Device support for a simple network ping J. Lewis Muir
Prev: ethercat 3-2 ronaldo.mercado
Next: CS-Studio MacrosInput class documentation Márcio Paduan Donadio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Device support for a simple network ping Dohn Arms
Next: Re: Device support for a simple network ping Martin L. Smith
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
