1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: sscan records
To: Christian Pauly <[email protected]>
Date: Wed, 9 Jul 2014 18:17:42 +0000
Hi Christian,
Do you have a file called color.def in your CSS workspace?  If not, there should be a default copy included with CSS.  I've never done a brand new install of CSS, so I don't know how that works.
Dyou have recent copies of the sscan-module .opi files?  The translation software has improved since I first started using it.  What versions of the sscan module and CSS are you using?
The most recent sscan-module .opi files are here:
https://subversion.xray.aps.anl.gov/synApps/sscan/trunk/sscanApp/op/opi/
Tim Mooney
Sent: Wednesday, July 09, 2014 12:48 PM
To: Mooney, Tim M.
Cc: EPICS Tech Talk
Subject: Re: sscan records
Thanks for advice
I got it working now, i guess i simply had a typo in the PV names.
I can run the scans now, and i can also save Data with saveData.
Now i am trying to set up the GUI using CSS. I found several example
opi-files in the sscanApp/op/opi Directory in the sscan package.
I managed to set the macro-variable $(P) in CSS, such that the PV-names
refer to my correct scan, however something is wrong with the display:
When i run the OPI, I just get a plain grey area, and all the letters
are grey on grey. I digged around in CSS for ages to find where i can
change color settings, but without success.
If i write an own opi, everything is fine, but all the example opi-files
have this annoying dark gray background.
Is there a simple trick to get these examples working ?
Re: sscan records Pete Jemian
Re: sscan records Christian Pauly
RE: sscan records Mooney, Tim M.
Prev: Re: sscan records Christian Pauly
Next: Re: sscan records Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
