1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: security rules and autosave
To: Touchard Dominique <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 Jul 2014 17:11:29 +0000
I get that behavior for any value of a PV used in an access-security rule,
whether it was defined in the database or restored by autosave.  If I
set PINI to get the record processed at init time, it behaves as I think it
should.
record(bo,"$(P)LocalAccess") {
    field(DESC,"AS for Local PCs")
    field(DTYP,"Soft Channel")
    field(ZNAM,"Disabled")
    field(ONAM,"Enabled")
    field(ASG, "controlFields")
    field(PINI, "YES")
    field(UDF, "0")
Tim
From: [email protected] [[email protected]] on behalf of Touchard Dominique [[email protected]]
Sent: Tuesday, July 22, 2014 7:25 AM
To: [email protected]
Subject: security rules and autosave
I need some advices on rules and autosave.
I configured a Linux IOC with following rules
ASG(FAISCEAU) {
#Operation mode lock
  INPA(DEFAULT:OPState)
#BEAM characteristics lock
  INPB(FAISCEAU:WritePerm)
# We can always read PVs
  RULE(1,READ)
# BEAM Characteristcs could be changed by everyone in maintenance mode and BEAM characteristics unlocked
  RULE(1,WRITE) { CALC("A=0 && B=1") }
# BEAM Characteristcs could be changed only by operators in operation mode and BEAM characteristics unlocked
  RULE(1,WRITE) {
    UAG(operateurs)
    CALC("A=1 && B=1")
DEFAULT:OPState could be 0:Maintenance 1:Operation
FAISCEAU:WritePerm could be 0:BEAMLocked 1:BEAMUnlocked
These rules work perfectly when values of DEFAULT:OPState and FAISCEAU:WritePerm are changed  manually.
At starting, with autosave mechanisme, there is a mismatch between right access and  lock values.
Any ideas?
Dominique.
RE: security rules and autosave Mooney, Tim M.
security rules and autosave Touchard Dominique
Prev: synApps usage on 64 bit systems Henrique Dante de Almeida
Next: RE: synApps usage on 64 bit systems Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: security rules and autosave Touchard Dominique
Next: RE: security rules and autosave Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
