1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Tabbed Container Ability
To: "Mark S. Engbretson" <[email protected]>
Date: Fri, 25 Jul 2014 07:38:32 +0000
I Mark,
I’ve solved my problem by adding button in each tab.
Thanks for your answer.
Charles-Henry
De : Mark S. Engbretson [mailto:[email protected]]
Envoyé : mercredi 23 juillet 2014 15:50
À : Patard Charles-Henri
Objet : RE: Tabbed Container Ability
Ø  Actually, it’s impossible to link script execution with the active tab property.
If the current tab set a PV or some other “global” state indicator, then scripts certainly could look at that PV and conditionally do or display something else. Although you would really have to brute force everything to make it work.
In the “old days” using MEDM, people just “faked” a similar effect by just making whole panels visible or invisible depending upon a PV, so effectively you might have any number of layers of content, only 1 which was actually visible at any particular time.
From: [email protected] [mailto:[email protected]] On Behalf Of Patard Charles-Henri
Sent: Wednesday, July 23, 2014 6:05 AM
To: [email protected]
Subject: Tabbed Container Ability
Hi all,
I’m trying to create an OPI with on left part a menu and on right part a display OPI area. The user can change the OPI on right part by selecting a tab on Tabbed container widget (left part).
I’ve thought of another solution but more complicated. Use a choice button widget and two linking container widgets. The first  linking container widgets is placed below the choice button and the second in the right part.
By clicking on the “tab button” the user display the menu and the OPI on the right part.
Is my need is legitimate ?
Thanks
Tabbed Container Ability Patard Charles-Henri
Prev: Re: EPICS alarming on VAL != X Andrew Johnson
Next: Re: EPICS alarming on VAL != X Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Tabbed Container Ability Patard Charles-Henri
Next: [no subject] Tim Waclawski
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
