1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Subroutine invoked only when PV limit exceeded?
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Jul 2014 11:13:41 -0500
Hi Mark,
On 07/28/2014 10:18 AM, Poff, Mark A wrote:
> In my EPICS database, for certain PVs I use forward links and sub
> records such that, whenever the PV value changes, a subroutine is
> called.  It’s a pretty basic implementation:
> record(longin, “MY_PV”)
>     field(SCAN, “Passive”)
>     field(HIHI, “30”)
>     field(HHSV, “MAJOR”)
>     field(FLNK, “MY_PV_sub”)
> record(“MY_PV_sub”)
>     field(INPA, “MY_PV”)
>     field(SNAM, “MY_PV_subroutine”)
> What I’d like to do additionally (or /_instead_/) is to call a
> subroutine only when MY_PV goes to the HIHI alarm state (in the example
> above, when the value of MY_PV goes from less than 30 to 30 or
> greater).  I assumed it could be done by somehow looking at MY_PV.SEVR,
> but I can’t figure out how to do it.  Is it possible to define the
> database records so that a subroutine is executed only when the
> associated PV goes into an alarm state?
You can use the SDIS link and DISV field of your MY_PV_sub record to do
part of that, see
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_dbCommon#Scan_Fields
for a brief description, but you'll only be able to disable the
subroutine on one of the alarm state/severity values (I might do that on
MY_PV.SEVR == 0). However your subroutine can read the alarm status and
severity through the existing INPA link and act accordingly. The code
you need would look something like this:
#include "dbAccessDefs.h"
#include "menuAlarmStat.h"
long MY_PV_subroutine(subRecord *prec)
    epicsEnum16 stat, sevr;
    if (dbGetAlarm(&prec->inpa, &stat, &sevr)) {
        /* Handle link problem ... */
    switch (stat) {
    case menuAlarmStatHIHI:
        break;
    case menuAlarmStatHIGH:
        break;
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Prev: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Next: Installing Pydev plugin for Control System Studio Derek Foster
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
