1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mbboDirect with ether_ip
Date: Thu, 31 Jul 2014 19:35:29 +0000
Hi:
Looking into this a little bit, the reason seems to be what Rod Nussbaumer reported in http://www.aps.anl.gov/epics/tech-talk/2012/msg02152.php, where it applied to mod bus driver.
On initialization, the etherIp driver is reading the correct PLC tag value into the mbboDirect's val and rval fields.
But when the record gets processed, it will read its B0, B1, … fields, combine those into VAL, and as a result Hovanes sees the same as Rod 2 years ago:
The record goes back to value 0 and for etherIp will then also write that 0.
I'll update the etherIp support similar to what Michael Davidsaver did for the softDevice support, i.e. the etherIp module will initialize the B0, B1, .. in addition to VAL, RVAL.
Kay
> From: [email protected] <[email protected]> on behalf of Hovanes Egiyan <[email protected]>
> Sent: Monday, July 14, 2014 11:31:03 AM
> To: [email protected]
> Cc: Hovanes Egiyan
> Subject: mbboDirect with  ether_ip
> Hi,
> we are using "ether_ip-2.24.1" EPICS module and EPICS base 3-14-12-3 for
> communicating with
> Allen-Bradley ControlLogix and CompactLogix PLC-s from GUIs. We need to
> use BOOL array tags in the
> PLC code,  and we would like to be able to change them from EPICS GUIs.
> We tried to use mbboDirect
> EPICS record type and we noticed that mbboDirect records set the
> corresponding BOOL array tags
> to zero every time the Linux IOC is rebooted, which is highly
> undesirable. Has anyone else seen such a behavior?
> I attached the EPICS DB file, the IOC booting script and the XML project
> file for the PLC project.
> Any suggestion would be appreciated.
> Hovanes Egiyan.
mbboDirect with ether_ip Hovanes Egiyan
Prev: EPICS Collaboration Meeting October 2014 mattei
Next: =?gb18030?b?u9i4tKO6ZXBpY3NxdCBvbiBhcm0gYm9hcmQ=?= =?gb18030?b?SGFuc2Vu?=
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: mbboDirect with ether_ip Hovanes Egiyan
Next: Potentiostat Adam Bark
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
