1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Launching CS-Studio BOY screens
To: <[email protected]>
Date: Tue, 12 Aug 2014 18:00:31 -0500
Hi Tom,
Since nobody else has bitten yet...
Have you considered using http: to deliver your screens to the users?
That appears to be the way that some sites are going, as it solves the
shared workspace problem and might simplify the soft-link management.
You might even be able to do some of your version selection on the
server-side instead of using soft-links if you wanted to.
That said I have no experience with doing this at all, so you'll have to
find out how to go about that from the real CS-Studio guys.
- Andrew
On 08/11/2014 09:30 AM, [email protected] wrote:
> Hi all,
> We're looking at how we should launch CS-Studio BOY screens on beamlines and machine, and have the following requirements:
> 1) If an IOC has a database template instance from a motor version 6-5, the screens for that IOC should come from motor 6-5.
> 2) One insertion device may have all its IOCs pointing at motor 6-5, but another may be at 6-4 or 6-2.
> 3) A user may want to launch sets of screens for many insertion devices at the same time.
> The same is true for beamlines, front ends, and other technical areas: a user may start at a high level screen, and drill down to a different version of the motor screen depending which IOC that component is on.
> For EDM we simply launched a new EDM for each insertion device with its own search path, but doing the same with CS-Studio would be quite resource hungry. We have had more than 20 instances of EDM running at once, and I wouldn't like to do the same with java virtual machines.
> We have come up with a proposal that would work for us:
> * Create a project for each insertion device (and beamline etc.) with soft links to the versions of each support module it uses
> * Run a command that tells the current running CS-Studio to import that project to the user's workspace and run a screen within it
> * We could then have one CS-Studio instance, and let each user have their own workspace, but manage the locations of the projects within it ourselves
> The eclipse navigator file structure would look like this:
> workspace/ # located in user's home directory
>   CSS/
>   ID1/     # Eclipse project pointing to /dls_sw/.../ID1/2-0
>     motor/ # Soft link in /dls_sw/.../ID1/2-0 pointint to /dls_sw/.../motor/6-5
>   ID2/     # Eclipse project pointing to /dls_sw/.../ID2/3-0
>     motor/ # Soft link in /dls_sw/.../ID1/3-0 pointint to /dls_sw/.../motor/6-2
> Has anyone else done anything similar? How do other sites launch CS-Studio BOY screens?
> Thanks,
> Tom Cobb
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: Launching CS-Studio BOY screens Michael Davidsaver
Launching CS-Studio BOY screens tom.cobb
Prev: RE: New to EPICS - system design questions Ryan Pierce
Next: How to tag soft channels as undefined/disconnected Kellee Summers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Launching CS-Studio BOY screens tom.cobb
Next: Re: Launching CS-Studio BOY screens Michael Davidsaver
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
