1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: FW: RE: how to install medm on ubuntu14.04
Date: Thu, 14 Aug 2014 14:55:28 +0000
Folks,
Just a follow up to say that the problem with building medm on Ubuntu14.04 is resolved.  There was some change in Ubuntu between 12 and 13 that requires additional linker flags.
Sent: Thursday, August 14, 2014 9:25 AM
To: Mark Rivers
Subject: Re: RE: how to install medm on ubuntu14.04
My problem has been resolved by adding 'dl' 'sm' 'lcd' to some files,  Thanks very much!
Best regards!
lisa
Date: 2014-08-14 11:31
To: zengzr
Subject: RE: RE: how to install medm on ubuntu14.04
The problem appears to be that Ubuntu now requires the -ldl flag to the linker.  I think you can set the environment variable LIBS=-ldl
Sent: Wednesday, August 13, 2014 9:12 PM
To: Mark Rivers
At the first, I use 憇udo apt-get install libX11-dev' to install libX11, and it's version is 1.6.2-1ubuntu2. I  uninstalled it and tried a lower version1.6.1 instead yesterday, the result of 'make' is the same as before.
Thanks a lot!
Best regards
lisa
Date: 2014-08-14 01:25
To: zengzr<mailto:[email protected]>
When you installed libX11 how did you do it?  Did you use the package manager for Ubuntu?  It should not let you install the wrong version.  When you installed the lower version did you get exactly the same error as on the higher version?
For CSS I am not an expert, but I know there is online documentation.
Sent: Tuesday, August 12, 2014 9:58 PM
To: Mark Rivers
thanks for your reply! I just tried a lower vision for libX11, but it still didn't work, is there any other way to fix it? if I use CSS instead of MEDM, where could I find any instruction or guideline? thanks!
Best regards
lisa
Date: 2014-08-12 20:32
To: zengzr<mailto:[email protected]>; tech-talk<mailto:[email protected]>
Subject: RE: how to install medm on ubuntu14.04
It looks to me like the version of libX11.a you have installed is newer than the version of glibc that you have on that system.  On Fedora libX11 comes from the package libX11-devel.  Is it possible that you installed a version of libX11 that is more recent than your version of Linux supports?
From: [email protected] [[email protected]] on behalf of zengzr [[email protected]]
Sent: Tuesday, August 12, 2014 4:11 AM
To: tech-talk
Subject: how to install medm on ubuntu14.04
I want to use 'areadetector' to control 'Prosilica GC750' camera for the first time. when I install 'medm' on ubuntu14.04 on my computer, it can't make successfully, the err as follows:
    /usr/bin/ld: /usr/lib/libX11.a(CrGlCur.o): undefined reference to symbol 'dlopen@@GLIBC_2.1'<mailto:'dlopen@@GLIBC_2.1'>
    //lib/i386-linux-gnu/libdl.so.2: error adding symbols: DSO missing from command line
    collect2: error:ld returned 1 exit status
    make[2]: ***[medm] Error 1
    make[2]: Leaving directory '/home/epics/extensions.src/medm3-1-9/medm/o.linux-x86'
    make[1]:***[install.linux-x86] Error 2
    make[2]: Leaving directory '/home/epics/extensions.src/medm3-1-9/medm'
    make:***[medm.install] Error 2
I don't know how to fix it, could you give me some advice on it? or if I use CSS, how to run areadetector and CSS? thanks very much!!
Best wishes!
lisa
Prev: Device Support for VME controller SIS3100 Florian Feldbauer
Next: Re: How to tag soft channels as undefined/disconnected Kellee Summers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: how to install medm on ubuntu14.04 Mark Rivers
Next: yet another python extension to channel access Xiaoqiang Wang
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
