1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: pyepics problem with PV.put(wait=True)
To: Jameson Graef Rollins <[email protected]>, EPICS tech-talk <[email protected]>
Date: Fri, 15 Aug 2014 02:06:57 +0000
Hi Jamie,
I suspect you are seeing a race condition.
The pv class by default sets the auto_monitor parameter to True.  This means that a CA monitor is put on the PV and PV.get just returns the last monitored value.
When you do pv.put(i, wait=True) that waits for the record to be processed, and all other records that process as a direct result of that record processing.  However, it does NOT wait for all CA monitor callbacks to complete.
You are doing pv.get immediately after the pv.put, and I suspect that the CA monitor callback has simply not had time to run.  I am not that familiar with the way that multi-threading works in Python, so I am not sure if you need to do anything to allow the CA callback a chance to happen between your pv.put and pv.get.
I think you can eliminate the problem by setting auto_monitor=False when you create the pv object.
From: [email protected] [[email protected]] on behalf of Jameson Graef Rollins [[email protected]]
Sent: Thursday, August 14, 2014 7:18 PM
To: EPICS tech-talk
Subject: pyepics problem with PV.put(wait=True)
Hi, folks.  I'm seeing what might be a bug in the behavior of PVs in the
pyepics interface, or at the very least something inconsistent with
advertised behavior.
I'm trying to use the wait=True option to PV.put() to wait for process
completion, after which I want to log the put action.  Here's a basic
example:
#!/usr/bin/env python
>From epics import PV
pv = PV('T1:TEST-SYS_B')
for i in range(10):
    print pv.get()
However, what I'm consistently getting as output from the above is
something like the following:
0.0
0.0
2.0
3.0
3.0
4.0
6.0
6.0
8.0
9.0
Note that the output is not at all what is expected: on three out of ten
writes a pv.get() immediately following a pv.put(wait=True) fails to
return the newly updated value.  I see the same failures if I instead
set use_complete=True and check for put_complete==True before issuing
pv.get().
If the put() has actually completed, why is the get() still seeing the
old value?
Thanks in advance for any help or suggestions.
jamie.
RE: pyepics problem with PV.put(wait=True) Mooney, Tim M.
pyepics problem with PV.put(wait=True) Jameson Graef Rollins
Prev: pyepics problem with PV.put(wait=True) Jameson Graef Rollins
Next: Re: pyepics problem with PV.put(wait=True) Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: pyepics problem with PV.put(wait=True) Mooney, Tim M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
