1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: synApps record
To: <[email protected]>, <[email protected]>
Date: Tue, 26 Aug 2014 11:40:42 +0000
HI Priya,
You have to define a dbd file that includes all the record and menu types you need in your application, and then point VDCT at that. Often, this is just a case of putting statements like:
DBD += <name>.dbd
<name>_DBD += <file1>.dbd <file2>.dbd ...
… into the Makefile in the application src directory. These then just get built into a single file called <name>.dbd in the dbd directory, and you can point your version of VDCT at that. However, you do have to do an initial make to create the file before you can run vdct.
You can also hand craft a default site-wide .dbd and use that.
More information is in the manual:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node5.html#SECTION00566000000000000000
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Sent: 26 August 2014 07:04
To: [email protected]
Subject: synApps record
Hello
          I am trying to use other records of synApps which is not in VDCT for eg. scalcout,transform,asyn etc.I have installed synApps_5_7 in EPICS folder , then How to use synApps record in my VDCT application?
What changes are required to be made in my own directory?plz help me
                            Thanks in advance....
synApps record priya tiwari
Prev: Re: synApps record Mazanec Tomáš
Next: RE: synApps record Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
