1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem with EPICS IOC on Windows x64
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Fri, 29 Aug 2014 14:33:53 +0300
Hi Epics users,
We modified somehow this file yesterday because we had some issues for loading the database. However, we saw few hours ago that we forgot this “#” and then we erased it.
Everything is fine now.
Bertrand DE BOISDEFFRE
Engineer
ELI-NP, Horia Hulubei National Institute for Physics and Nuclear Engineering
30 Reactorului Street,
077125 Magurele, Romania
+4021 404 50 89 / 021 404 50 89
www.eli-np.ro
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Friday, August 29, 2014 2:18 PM
To: [email protected]
“TOP” should get defined by the “envPaths” file, and it looks like the reading of this is commented out in your st.cmd file.
Try removing the “#” from the start of the “< envPaths” line
Freddie
Sent: 29 August 2014 07:02
To: Mazanec Tomáš; Mark Rivers
Subject: Re: Problem with EPICS IOC on Windows x64
I did what Mr. Rivers said I was able to get the IOC to start with the .dbd file attached but now I cannot attach the .db file.
C:\Users\Epics\Documents\Example\iocBoot\iocExample>C:\Users\Epics\Documents\Exa
mple\bin\win32-x86-mingw\test st.cmd
#!../../bin/win32-x86-mingw/test.exe
## You may have to change test to something else
## everywhere it appears in this file
#< envPaths
macLib: macro TOP is undefined (expanding string cd ${TOP})
dbLoadDatabase "dbd/test.dbd"
filename="../dbLexRoutines.c" line number=243
No such file or directory dbRead opening file dbd/test.dbd
test_registerRecordDeviceDriver pdbbase
registerRecordDeviceDriver failed aai
registerRecordDeviceDriver failed aao
registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed ao
registerRecordDeviceDriver failed aSub
registerRecordDeviceDriver failed bi
registerRecordDeviceDriver failed bo
registerRecordDeviceDriver failed calc
registerRecordDeviceDriver failed calcout
registerRecordDeviceDriver failed compress
registerRecordDeviceDriver failed dfanout
registerRecordDeviceDriver failed event
registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed longin
registerRecordDeviceDriver failed longout
registerRecordDeviceDriver failed mbbi
registerRecordDeviceDriver failed mbbiDirect
registerRecordDeviceDriver failed mbbo
registerRecordDeviceDriver failed mbboDirect
registerRecordDeviceDriver failed permissive
registerRecordDeviceDriver failed sel
registerRecordDeviceDriver failed seq
registerRecordDeviceDriver failed state
registerRecordDeviceDriver failed stringin
registerRecordDeviceDriver failed stringout
registerRecordDeviceDriver failed sub
registerRecordDeviceDriver failed subArray
registerRecordDeviceDriver failed waveform
registerRecordDeviceDriver failed xxx
## Load record instances
dbLoadTemplate "db/userHost.substitutions"
dbLoadTemplate: error opening sub file db/userHost.substitutions
dbLoadRecords "db/dbExample1.db", "user=EpicsHost"
No such file or directory dbRead opening file db/dbExample1.db
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
traceIocInit
iocInit will be traced
macLib: macro TOP is undefined (expanding string cd ${TOP}/iocBoot/${IOC})
macLib: macro IOC is undefined (expanding string cd ${TOP}/iocBoot/${IOC})
iocInit
iocInit: Reached initHookAtIocBuild
Starting iocInit
checkDatabase: menuConvert not defined.
iocBuild: Aborting, bad database definition (DBD)!
## Start any sequence programs
#seq sncExample, "user=EpicsHost"
epics>
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
2014-08-28 19:11 GMT+03:00 Mazanec Tomáš <[email protected]>:
Hi
I simply followed this guide for base & IOC compilation:
http://aps.anl.gov/epics/base/win32.php
And if I remember my tests correctly, I had to execute win.bat prior to IOC execution. Win.bat sets  environment variables --- also for perl and mingw.
Tomas
Od: [email protected] [[email protected]] za uživatele Vlad Andrei Rusu [[email protected]]
Odesláno: 28. srpna 2014 15:02
Komu: [email protected]
Předmět: Problem with EPICS IOC on Windows x64
Hello EPICS users.
We are trying to run an IOC on Windows x64 using mingw, and we encountered some problems, as the title states. First of all, we are having a problem with the IOC .dbd file, the IOC initializes but from what we understood, st.cmd is not running, when we are trying to run just this file, it gives us the error:
# is not a recognized command.
Perl is installed and in Path,
Mingw is installed and in Path.
We can enter epics shell, the commands work, we can open the .dbd and .db device in VDCT.
But when we use "dbl" it says:"No database loaded".
We were able to run MEDM as well, and here comes the second problem, how can we install the fonts required by MEDM? On the EPICS webpage, the link towards downloads it's just a .txt file, we tried to use save link as but it did not work.
Kind Regards
Rusu Vlad Andrei & Bertrand de Boisdeffre
Problem with EPICS IOC on Windows x64 Vlad Andrei Rusu
RE: Problem with EPICS IOC on Windows x64 Mazanec Tomáš
Re: Problem with EPICS IOC on Windows x64 Vlad Andrei Rusu
RE: Problem with EPICS IOC on Windows x64 freddie.akeroyd
Prev: RE: Problem with EPICS IOC on Windows x64 freddie.akeroyd
Next: Open position at PSI Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
