1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: synApps_5_7 build error on Windows 8.1 x64
To: "'Alireza Panna'" <[email protected]>
Date: Fri, 29 Aug 2014 15:11:22 +0000
No, I mean that when you get the lemon.exe dialog box, is there a button you can push to debug (some dialog boxes have this).
If not, then open the Visual Studio debugger and attach it to the lemon.exe process before it exits (before you acknowledge the dialog).  It may show you the problem.
Sent: Friday, August 29, 2014 10:09 AM
To: Mark Rivers
Cc: Benjamin Franksen; [email protected]
Subject: Re: synApps_5_7 build error on Windows 8.1 x64
Hello Mark,
I am using base 3.14.12.4. Do you mean debugging snl.c in vs debugger?
Alireza Panna
On Friday, August 29, 2014, Mark Rivers <[email protected]> wrote:
What version of EPICS base are you using?  I am using 3.14.12.4.  Note that prior to version 3.14.12.3 the stack size on Windows was very small and that could be the problem.
When you get the popup dialog about lemon.exe can you then debug it in the Visual Studio debugger?  That may tell you if the problem is an access violation, missing DLL, stack overflow, etc.
Sent: Friday, August 29, 2014 9:52 AM
To: Mark Rivers
Hello Benjamin and Mark,
I tried doing make clean in C:\Epics\support\seq-2-1-13\src\snc\O.windows-x64 and then ..\\..\\..\\bin\\windows-x64\\lemon.exe o=. ../snl.lem, However I get the same error with the pop-up saying lemon.exe has stopped working.
Even doing make clean in the windows-x64 dir gives me the same pop-up.
I have previously compiled seq on Windows 7 x64 and I know that seq 2-1.13 gives an error in UserfuncEf..c and I think I had to use seq-2.1.16 which worked well.
Also I am using MS Visual Studio Express 2013 when I set the environment I call "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\x86_amd64\vcvarsx86_amd64.bat". May be i try and switch to 2010 and see if it works
Thank you
Alireza Panna
Alireza Panna
University of Maryland, College Park
On Fri, Aug 29, 2014 at 7:27 AM, Mark Rivers <[email protected]> wrote:
I just tried building the following versions of the sequencer on windows-x64 (Windows 7, Visual Studio 2010, GNUWin32 make).
seq-2.1.10
seq-2.1.13
seq-2.2.0.1
2.1.10 built with no errors.
2.1.13 did not have the error with lemon.exe that was the subject of this thread.  Here is the output when lemon.exe is being used:
make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install
make[3]: Entering directory `J:/epics/devel/seq-2-1-13/src/snc/O.windows-x64'
3 parsing conflicts.
re2c.exe -s -b -o lexer.c ../snl.re
make[3]: Leaving directory `J:/epics/devel/seq-2-1-13/src/snc/O.windows-x64'
However, 2.1.13 did fail much later in the build with the following error:
"converting userfuncEf.i"
../../../bin/windows-x64/snc.exe   +m -i  userfuncEf.i -o userfuncEf.c.tmp
perl -MExtUtils::Command -e mv userfuncEf.c.tmp userfuncEf.c
cl -c             /favor:blend   /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT -DEPICS_DLL_NO    -I. -I..\\O.Common
-I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IH:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IH:\\epics\\base-3.14.12.4\\include       userfuncEf.c
userfuncEf.c
userfuncEf.c(13) : error C2016: C requires that a struct or union has at least one member
../userfuncEf.st(26) : error C2059: syntax error : '}'
make[3]: *** [userfuncEf.obj] Error 2
make[3]: Leaving directory `J:/epics/devel/seq-2-1-13/test/validate/O.windows-x64'
make[2]: *** [install.windows-x64] Error 2
make[2]: Leaving directory `J:/epics/devel/seq-2-1-13/test/validate'
make[1]: *** [validate.install] Error 2
make[1]: Leaving directory `J:/epics/devel/seq-2-1-13/test'
make: *** [test.install] Error 2
2.2.0.1 failed very early in the build with the following error:
"Installing generic include file ../../../include/seq_prim_types.h"
-I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include -IH:\\epics\\base-3.14.12.4\\include\\os\\WIN32 -IH:\\epics\\base-3.14.12.4\\include       ..\\seq_main.c
seq_main.c
..\seq_main.c(282) : error C2124: divide or mod by zero
make[3]: *** [seq_main.obj] Error 2
make[3]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src/seq/O.windows-x64'
make[2]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src/seq'
make[1]: *** [seq.install] Error 2
make[1]: Leaving directory `J:/epics/devel/seq-2-2-0-1/src'
make: *** [src.install] Error 2
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Benjamin Franksen
Sent: Friday, August 29, 2014 4:56 AM
To: [email protected]
Cc: Alireza Panna
On Thursday 28 August 2014 16:54:00 Alireza Panna wrote:
> Hello all,
> I am having trouble building the sequencer module. base compiles fine
> under windows-x64, however when i try to build the sequencer module
> in synApps-5-7, I get the following error:
> make[3]: Entering directory `C:/Epics/support/seq-2-1-13/src/snc'
> install make[4]: Entering directory
> `C:/Epics/support/seq-2-1-13/src/snc/O.windows-x64'
> make[4]: Leaving directory
>  /D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MD     -I.
> -I..\\O.C
> ommon -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
> -IC:\\Epic
> s\\base\\include\\os\\WIN32 -IC:\\Epics\\base\\include       lexer.c
> lexer.c
> ../snl.re (16) : fatal error C1083: Cannot open include file: 'snl.h':
> No such fi
> le or directory
> make[4]: *** [lexer.obj] Error 2
> make[3]: *** [install.windows-x64] Error 2
> make[3]: Leaving directory `C:/Epics/support/seq-2-1-13/src/snc'
> make[2]: *** [snc.install] Error 2
> make[2]: Leaving directory `C:/Epics/support/seq-2-1-13/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `C:/Epics/support/seq-2-1-13'
> make: *** [C:/Epics/support/seq-2-1-13.install] Error 2
> Before this error occurs, I get a pop up saying lemon.exe has stopped
> working.
Hm, that sounds like the bundled version of lemon crashes (or otherwise
misbehaves) when compiled as a win64 executable. In this case it would
not generate snl.h which is what the error message says.
To clarify this, please
> cd C:/Epics/support/seq-2-1-13/src/snc/O.windows-x64
> make clean
and then
It should say "3 parsing conflicts." and there should now exist files
named snl.c, snl.h, and snl.out in this directory. If not (or if one of
these files is empty), then lemon is broken on win64 and I will see
whether the upstream version has a fix for the problem.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Alireza Panna
synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
Re: synApps_5_7 build error on Windows 8.1 x64 Benjamin Franksen
RE: synApps_5_7 build error on Windows 8.1 x64 Mark Rivers
Re: synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
Prev: Re: synApps_5_7 build error on Windows 8.1 x64 Alireza Panna
Next: motorApp R6.8 Mclennan PM600 opposite limit datum search mode on linux-arm Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: synApps_5_7 build error on Windows 8.1 x64 Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
