1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream device get started?
To: EPICS Tech-Talk <[email protected]>
Cc: Alireza Panna <[email protected]>
Date: Tue, 02 Sep 2014 09:35:18 +0200
On 01/09/2014 21:00, Mark Rivers wrote:
EPICS_HOST_ARCH  env var is set and so is ASYN.
These should not be set as environment variables, they should be defined in the configure/RELEASE file of your application.
Well...
While definitions of external modules like ASYN should always go into the configure/RELEASE file (it is named RELEASE because it defines the exact releases of external modules that you are using), EPICS_HOST_ARCH is meant to be set in the environment. While setting it in configure/RELEASE might work, the host architecture is rather a property of the host than a definition of an external module.
As soon as you put your sources on a network drive and compile it for multiple host architectures inside the same structure, setting the host architecture in configure/RELEASE is obviously not a good idea.
~Ralph
RE: stream device get started? Mark Rivers
stream device get started? Alireza Panna
Prev: Re: Making two computers communicate. Vlad Andrei Rusu
Next: Re: Making two computers communicate. Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: stream device get started? Mark Rivers
Next: RE: stream device get started? Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
