Adjusting the time is the first thing I tried of course... but although the typical response time is very short, i.e. a couple of ms, after a while, I get the "No reply from device within x ms" even with a timeout set to something ridiculous like 10000ms
The protocol is very simple: are_you_done { out "done?"; in "%b"; } I just tried to use an EVENT record: i.e. FWDLINK the BI record to the EVENT record and set the SCAN field of the BI record to that event... but same error eventually comes up. The only remedy is to kill and restart the IOC.
David On 3 September 2014 13:08, Mark Rivers <[email protected]> wrote: What is the maximum/typical time between when you send a query and receive a response?
| ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
