1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Processing a record a in loop
To: "Dalesio, Leo" <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 3 Sep 2014 14:55:30 +0100
Thanks Bob, I'm aware of being able to change the scan rate this way. But longer scan rate is not really desirable. The typical task performed by the device is only a couple of seconds, so long scan rate for status updates would be close to useless.
David
Dr. David Michel
Address: 8 Viking Drive, Didcot, OX11 9RD, Oxfordshire
Mobile: 0789 670 98 01 - Home: 0123 581 46 93
On 3 September 2014 14:26, Dalesio, Leo <[email protected]> wrote:
If you need a longer scan rate - you can modify menu.dbd. I think that the instructions in the Application Developer's Guide covers this.
Bob
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Wednesday, September 03, 2014 8:08 AM
To: David Michel; EPICS mailing list
Subject: RE: Processing a record a in loop
What is the maximum/typical time between when you send a query and receive a response?
You should be able to set the timeout to a value just longer than the maximum and then you can process the record with any fixed rate (1 seconds, 10 seconds, etc.).  The record will be busy (PACT=1) if the next scan interval happens before the reply from the previous one.  So it will not keep sending query messages, it will wait for a reply before proceeding.
What does your protocol file look like?  Is it a single query per response, etc.?
From: [email protected] [[email protected]] on behalf of David Michel [[email protected]]
Sent: Wednesday, September 03, 2014 6:02 AM
To: EPICS mailing list
Subject: Processing a record a in loop
Hi All,
I'm using StreamDevice to talk to a custom device that doesn't support I/O interrupt so one has to keep sending commands to it to get status information.
Problem is that after a while (~ couple of hours), the device's buffer fills up and doesn't reply anymore. Increasing the ReplyTimeOut improves things slightly, but the problem still eventually occurs.
One potential solution would be to send the next command only once the previous one has returned in a loop (instead of using a set frequency).
Making the record FWD link to itself doesn't seem to do it... I started something using purely database trickery with a FANOUT record set with a fixed SCAN field and disabling it depending on whether the streamdevice record has finished processing or not... but it's getting messy
Is there an elegant way of doing this?
David
Re: Processing a record a in loop Rod Nussbaumer
Processing a record a in loop David Michel
RE: Processing a record a in loop Mark Rivers
RE: Processing a record a in loop Dalesio, Leo
Prev: RE: asyn record Mooney, Tim M.
Next: Re: Processing a record a in loop David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Processing a record a in loop Dalesio, Leo
Next: Re: Processing a record a in loop Rod Nussbaumer
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
