1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: scalcout with streamDevice - request for guidance and example
To: <[email protected]>
Date: Thu, 4 Sep 2014 10:24:50 +0000
I am trying to use an scalcout record with a stream device protocol  and  I need to capture a string value  in one of the string fields.  I already have calcout records working to do an equivalent job to capture a numeric field.  The protocol makes use of the field name syntax to access the record letter fields.
The stream device online manual states scalcout  records are allowed since v2-1 and work since 2-6-1 of calc module, the IOC is built for linux-x86 with streamDevice v2-5dls2, v3-1 of calc, with v2-8-1 of sscan and v1-8dls2-9 of genSub under EPICS R3.14.11 and I have added dbd and library entries to the Makefile for these modules.
I copied my functioning calcout record (with DTYP stream), changed it to scalcout and edited it to call the protocol.
dbLoadRecords results in the following error message for the scalcout records:
Can't set "TS-VA-TURBO-03:GET:PARAM:DATATYPE4.DTYP" to "stream"
Examining the built dbd file I can find
device(calcout,CONSTANT,devCalcoutSoft,"Soft Channel")
device(calcout,CONSTANT,devCalcoutSoftCallback,"Async Soft Channel")
device(calcout,INST_IO,devcalcoutStream,"stream")
device(scalcout,CONSTANT,devsCalcoutSoft,"Soft Channel")
It appears that only Soft Channel DTYP is available to scalcout.  Was it wrong of me to expect DTYP stream to be available or am I missing something from the IOC or module builds?
Is there a working example of scalcout and stream being used together I can look at?
Linda
Re: scalcout with streamDevice - request for guidance and example Martin L. Smith
Prev: Re: Processing a record a in loop David Michel
Next: Re: scalcout with streamDevice - request for guidance and example Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Who uses WAGO or Beckhoff PLCs for Equipment Protection Systems? [SEC=UNCLASSIFIED] Bryce Karnaghan
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
