1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Installing synApps
Date: Fri, 5 Sep 2014 09:07:14 +0300
Hello again, EPICS users,
I managed to connect the 2 PCs, with your help, which is greatly appreciated. It was an issues with the firewall on linux.
Now, I want to be able to create an IOC for a Stanford Research DG645 to be able to remotely monitor and control data.
I unpacked synApps, modified RELEASE to point to EPICS and synApps top folder but then I try to use "mingw32-make.exe release" it says:
C:\Users\Epics\D
C:\Users\Epics\Documents\synApps\synApps_5_7\support>mingw32-make.exe release
C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc
uments\synApps\synApps_5_7\support: Permission denied
C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User
s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same
rule.
C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ
e' given more than once in the same rule.
rule.
rule.
rule.
rule.
rule.
And it just goes on in a loop until I cancel it
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
Prev: RE: Processing a record a in loop Emmanuel Mayssat
Next: BEAST configuration Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: org.csstudio.auth plug-ins Silver
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
