1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin
To: <[email protected]>
Date: Fri, 5 Sep 2014 17:06:41 -0500
On 09/05/2014 04:52 PM, J. Lewis Muir wrote:
> When I try to run the areaDetector 1.9.1 simulated detector IOC on
> Darwin (Mac OS X), it aborts immediately with the error, "dyld: Symbol
> not found: __ZNSs4_Rep20_S_empty_rep_storageE":
Running that symbol through c++filt on a Mac gives the following
unmangled name:
woz$ c++filt __ZNSs4_Rep20_S_empty_rep_storageE
std::string::_Rep::_S_empty_rep_storage
Doing a web search on that implies that you need to link against
libstdc++, so try adding this to the Makefile that builds simDetectorApp:
    OP_SYS_LDLIBS += -lstdc++
If that fixes it on Darwin there will need to be some adjustments to
make it cross-platform.
- Andrew
> $ cd /opt/synapps-5.6/support/areaDetector-1-9-1/iocBoot/iocSimDetector
> $ ../../bin/darwin-x86/simDetectorApp st.cmd.darwin
> dyld: Symbol not found: __ZNSs4_Rep20_S_empty_rep_storageE
>   Referenced from: /opt/synapps-5.6/support/areaDetector-1-9-1/lib/\
> darwin-x86/libNDPlugin.3.14.12.dylib
>   Expected in: flat namespace
>  in /opt/synapps-5.6/support/areaDetector-1-9-1/lib/darwin-x86/\
> Trace/BPT trap: 5
> I searched the Web but couldn't find much.  All I found was something
> about _S_empty_rep_storage being an empty std::string something or
> other.  Does anyone know what's wrong and how to fix it?
> Environment:
> * areaDetector 1.9.1
> * EPICS Base 3.14.12.4 + Known Problems patches
> * EPICS Architecture: darwin-x86
> * EPICS Architecture Class: x86_64
> * Xcode 5.1.1
> * Mac OS X 10.9.4
> Thank you!
> Lewis
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Prev: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Next: Re: areaDetector 1.9.1 "dyld: Symbol not found" on Darwin J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
