What field is the client writing to? The VAL field or an individual bit?
In R4-21 the following change was made:
“Improved the initMbboDirect function in devAsynUInt32Digital.c. If an initial value is read successfully from the driver it now sets the .Bn fields in the record. It also sets VAL rather than RVAL and returns 2 rather than 0. Thanks to Andrew Johnson for
this.”
Sent: Monday, September 08, 2014 3:50 PM
To: EPICS mailing list
Subject: mbboDirect problems
I have a number of mbboDirect records like:
record(mbboDirect, "$(P)$(R)EVR:event12trig") {
field(DESC, "Extraction pre-trigger")
field(DTYP, "asynUInt32Digital")
field(OUT, "@asynMask($(PORT) 0x30C 0xFF 0)")
The IOC starts up and reads back the initial value of this record properly.
The *first* caput to the record (I’ve tried from EDM and from caput) writes the readback value again, not the value from the client.
Subsequent caputs do write the value from the client. It’s only the first operation that uses old data.
- Re: mbboDirect problems Eric Norum
- mbboDirect problems Eric Norum
<2014>
2025
2026
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
