You won't be able to build support until you build base. So the first problem to fix is building base.
What version of Cygwin/gcc are you running?
gcc --version
I would also recommend upgrading to base 3.14.12.4.
I built base 3.14.12.4 on my Cygwin system yesterday, so I know that should work. It is a "recent" upgrade of Cygwin, but I can't tell you the version of gcc till I get to work in a couple of hours.
I did have problems building the synApps sscan (SVN HEAD) and asyn (4-23) modules with cygwin-x86. This is due to dynamic builds on Cygwin being stricter than Visual Studio about the location of dllexport and dllimport declarations.
Hopefully these will be fixed today.
From: [email protected] [[email protected]] on behalf of Vlad Andrei Rusu [[email protected]]
Sent: Wednesday, September 10, 2014 4:15 AM
To: [email protected]
Subject: Problems with synApps and Epics using Cygwin on Windows
Hello users of Epics
We have several problems using 'make' in Cygwin on Windows with synApps and Epics base.
When we try to use 'make support' as stated in synApps install guide, we get the following error:
Epics@DEV-PC /opt/synApps_5_7/support
$ make
Can't open perl script "C:UsersEpicsDocumentsbase-3.14.12.3/bin/cygwin-x86/conve rtRelease.pl": No such file or directory
C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:50: *** target patt ern contains no '%'. Stop.
and when we try to 'make' Epics base we get the following errors:
gcc -c -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/os i/os/cygwin32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/de fault -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../.. /src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I.. /../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libC om/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../ src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I ../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd !
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/c ygwin32 -I../../../include ../../../src/libCom/calc/postfix.c
../../../src/libCom/calc/postfix.c: In function ‘postfix’:
../../../src/libCom/calc/postfix.c:482:1: error: unrecognizable insn:
(insn 537 536 538 104 (set (reg/f:SI 312)
(symbol_ref:SI ("__ctype_ptr__") [flags 0x440] <var_decl 0x6ffffd389c0 _ _ctype_ptr__>)) ../../../src/libCom/calc/postfix.c:178 -1
(nil))
../../../src/libCom/calc/postfix.c:482:1: internal compiler error: in extract_in sn, at recog.c:2154
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
../../../configure/RULES_BUILD:199: recipe for target 'postfix.o' failed
make[3]: *** [postfix.o] Error 1
make[3]: Leaving directory '/opt/base-3.14.12.3/src/libCom/O.cygwin-x86'
../../configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86' failed
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory '/opt/base-3.14.12.3/src/libCom'
../configure/RULES_DIRS:70: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory '/opt/base-3.14.12.3/src'
configure/RULES_DIRS:70: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Thank you in advance.
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
E: [email protected]<mailto:[email protected]>
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
- RE: Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
- Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
RE: Problems with synApps and Epics using Cygwin on Windows Mazanec Tomáš
Re: Device Support Options for NI RIO Ralph Lange
<2014>
2025
2026
Re: Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
<2014>
2025
2026
