1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problems with synApps and Epics using Cygwin on Windows
To: Mazanec Tomáš <[email protected]>
Cc: [email protected]
Date: Wed, 10 Sep 2014 16:09:36 +0300
Yes, there are backslashes missing in cygwin shell but in Path, it is defined corectly.
On 10 Sep 2014 15:05, "Mazanec Tomáš" <[email protected]> wrote:
Hello
The directory path to perl script seems to be wrong -- are there backslash chars missing ?
Can't open perl script "C:UsersEpicsDocumentsbase-3.14.12.3/bin/cygwin-x86/convertRelease.pl": No such file or directory
Tomas
Od: [email protected] [[email protected]] za uživatele Vlad Andrei Rusu [[email protected]]
Odesláno: 10. září 2014 11:15
Komu: [email protected]
Předmět: Problems with synApps and Epics using Cygwin on Windows
Hello users of Epics
We have several problems using 'make' in Cygwin on Windows with synApps and Epics base.
When we try to use 'make support' as stated in synApps install guide, we get the following error:
Epics@DEV-PC /opt/synApps_5_7/support
$ make
Can't open perl script "C:UsersEpicsDocumentsbase-3.14.12.3/bin/cygwin-x86/conve                    rtRelease.pl": No such file or directory
C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:50: *** target patt                    ern contains no '%'.  Stop.
and when we try to 'make' Epics base we get the following errors:
gcc -c  -D_POSIX_THREADS -D_POSIX_TIMERS            -DUNIX  -DCYGWIN32     -O3                       -Wall      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src/libCom/os                    i/os/cygwin32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/de                    fault -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../..                    /src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I..                    /../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/                    ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libC                    om/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../                    src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I                    ../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd                     -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/c                    ygwin32 -I../../../include        ../../../src/libCom/calc/postfix.c
../../../src/libCom/calc/postfix.c: In function ‘postfix’:
../../../src/libCom/calc/postfix.c:482:1: error: unrecognizable insn:
(insn 537 536 538 104 (set (reg/f:SI 312)
        (symbol_ref:SI ("__ctype_ptr__") [flags 0x440] <var_decl 0x6ffffd389c0 _                    _ctype_ptr__>)) ../../../src/libCom/calc/postfix.c:178 -1
     (nil))
../../../src/libCom/calc/postfix.c:482:1: internal compiler error: in extract_in                    sn, at recog.c:2154
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
../../../configure/RULES_BUILD:199: recipe for target 'postfix.o' failed
make[3]: *** [postfix.o] Error 1
make[3]: Leaving directory '/opt/base-3.14.12.3/src/libCom/O.cygwin-x86'
../../configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86' failed
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory '/opt/base-3.14.12.3/src/libCom'
../configure/RULES_DIRS:70: recipe for target 'libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory '/opt/base-3.14.12.3/src'
configure/RULES_DIRS:70: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Thank you in advance.
Kind Regards
Rusu Vlad Andrei
T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
RE: Problems with synApps and Epics using Cygwin on Windows Mazanec Tomáš
Prev: Re: Device Support Options for NI RIO Ralph Lange
Next: RE: Problems with synApps and Epics using Cygwin on Windows Vlad Andrei Rusu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problems with synApps and Epics using Cygwin on Windows Mazanec Tomáš
Next: Re: Problems with synApps and Epics using Cygwin on Windows Zachary Brown
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
