1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: msi missing when isntalling synApps
To: "'Vlad Andrei Rusu'" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 11 Sep 2014 15:25:54 +0000
> /bin/sh: msi: command not found
Either add msi to your PATH or add the MSI environment variable to configure/CONFIG_SITE:
MSI=<path-to-your-extensions>/bin/$(EPICS_HOST_ARCH)/msi
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Vlad Andrei Rusu
> Sent: Thursday, September 11, 2014 6:40 AM
> To: [email protected]
> Subject: msi missing when isntalling synApps
> Hello once again
> We decided to install synApps on Linux and once again, some errors.
> I am getting the following error when trying to "make" synApps, I have downlaoded msi,
> put it extensions/src and 'make' src folder. I also used 'make release' in synApps/support/;
> msi   -I. -I.. -I../O.Common -I../../../db -I/opt/epics/base-3.14.12.3/db ../ioc.template >
> ioc.tmp
> make[4]: *** [../O.Common/ioc.db] Error 127
> make[4]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-
> 7/iocAdmin/Db/O.linux-x86_64'
> make[3]: *** [install.linux-x86_64] Error 2
> make[3]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin/Db'
> make[2]: *** [Db.install] Error 2
> make[2]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7/iocAdmin'
> make[1]: *** [iocAdmin.install] Error 2
> make[1]: Leaving directory `/opt/synApps_5_7/support/devIocStats-3-1-7'
> make: *** [/opt/synApps_5_7/support/devIocStats-3-1-7.install] Error 2
> Thank you once again!
> Kind Regards
> Rusu Vlad Andrei
> T: (+004)0755.052.954
> E: [email protected]
> A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
msi missing when isntalling synApps Vlad Andrei Rusu
Prev: Re: Keithley 2400 communication Rod Nussbaumer
Next: stream device with Keithley 2410 Alireza Panna
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: msi missing when isntalling synApps Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
