Hi Prerana,
I think your problemis probably this line in serialTest/configureRELEASE
ASYN = /home/cfsd/pkankiya/EPICS/base-3.14.12.4/modules/asyn4-21/asyn
I think this should probably be:
i.e. it should not have the final /asyn. ASYN should point to the top-level of asyn, which should look like this:
corvette:~/devel/asyn>ls
LLICENSE asyn configure dbd include lib opi testApp testConnectApp testErrorsApp testGpibSerialApp testManagerApp
Makefile bin db documentation iocBoot makeSupport templates testAsynPortDriverApp testEpicsApp testGpibApp testIPServerApp testUsbtmcApp
Try that and see if it works. If not then please send a directory listing of /home/cfsd/pkankiya/EPICS/base-3.14.12.4/modules/asyn4-21
Sent: Wednesday, September 24, 2014 8:15 PM
To: Mark Rivers; [email protected]
Subject: RE: asyn build unsuccessful
Hi Mark,
- The path to EPICS base
- The path to asyn
- The path to serialTest
Please send the contents of the following file:
serialTest/configure/RELEASE
attached.
and send a directory listing of
asyn/dbd
asyn.dbd devAsynInt16Array.dbd devAsynRecord.dbd drvAsynIPPort.dbd testAsynPortDriver.dbd testManager.dbd
asynRecord.dbd devAsynInt32.dbd devAsynUInt32Digital.dbd drvAsynSerialPort.dbd testEpics.dbd
devAsynFloat32Array.dbd devAsynInt32Array.dbd devEpics.dbd drvGsIP488.dbd testErrors.dbd
devAsynFloat64.dbd devAsynInt32TimeSeries.dbd devGpib.dbd drvNi1014.dbd testGpib.dbd
devAsynFloat64Array.dbd devAsynInt8Array.dbd devTestBlock.dbd drvVxi11.dbd testGpibSerial.dbd
devAsynFloat64TimeSeries.dbd devAsynOctet.dbd devTestGpib.dbd test.dbd testIPServer.dbd
I can provide any other information you suggest Thank you for helping out.
Best,
Prerana
From: [email protected] [[email protected]] on behalf of Prerana Kankiya [[email protected]]
Sent: Wednesday, September 24, 2014 4:42 PM
To: [email protected]
Subject: Fwd: asyn build unsuccessful
Hi ,
I wanted to share the build errors I have been getting when trying to get a basic asyn app going.
1. First I installed the EPICS base package and build the base without errors
2. I installed asyn under a modules directory in the base package.
3. Then I followed instructions here <http://www.aps.anl.gov/epics/modules/soft/asyn/AsynRecordControl/AsynRecordControl.html>
4. When I try to execute step 4 , I get these errors
make -C ./configure install
make[1]: Entering directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/configure/O.linux-x86_64'
perl ../../../bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/configure/O.linux-x86_64'
make[1]: Leaving directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/configure'
make -C ./serialTestApp install
make[1]: Entering directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp'
make -C ./src install
make[2]: Entering directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp/src/O.linux-x86_64'
echo "../O.Common/serialTestInclude.dbd : ../Makefile" >> serialTest.dbd.d
Expanding dbd
Can't open include file "drvVxi11.dbd"
Error at or before ""drvVxi11.dbd"" in file "../O.Common/serialTestInclude.dbd" line 2
dbExpand: Input errors, no output generated
make[3]: *** [../O.Common/serialTest.dbd] Error 1
make[3]: Leaving directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp/src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/cfs/ad/pkankiya/EPICS/base-3.14.12.4/serialTest/serialTestApp'
make: *** [serialTestApp.install] Error 2
I am guessing I am building from wrong directory. Kindly suggest.
Thank you,
Prerana
- Fwd: asyn build unsuccessful Prerana Kankiya
- RE: asyn build unsuccessful Mark Rivers
- RE: asyn build unsuccessful Kankiya, Prerana
does anyone use s7-nodave driver? Silver
<2014>
2025
2026
<2014>
2025
2026
