We have a soft IOC that we use to control several serial devices, via
StreamDevice on Asyn communicating over Ethernet to TCP/IP ports on a
Moxa serial device server.
Usually this works, but recently a serial device did not respond to
several commands from the IOC. We saw several messages indicating
that Asyn disconnected, then reconnected to its port on the server.
Messages logged by asynTrace and other details appear below.
Does anyone have an explanation for this? We did not notice any
unusual events on the network, other than this.
Jon Jacky
This is asyn-4-17 running on EPICS 3.14.12 on Debian Linux with kernel
3.2.0-3-686-pae running on an i686. Code etc. appears below.
Here are excerpts from asynTrace logs. A normal command/reponse looks
like this. The IOC named process-ioc sends an escape character (33
hex) and the controller responds with a banner:
process-ioc:47630 Wed Sep 24 13:57:12 2014 2014/09/24 13:57:08.476 ctlr wrote
process-ioc:47630 Wed Sep 24 13:57:12 2014 \033\r
process-ioc:47630 Wed Sep 24 13:57:12 2014 2014/09/24 13:57:09.480 ctlr asynOctetB\
ase interrupt
process-ioc:47630 Wed Sep 24 13:57:12 2014 2014/09/24 13:57:09.480 ctlr read
process-ioc:47630 Wed Sep 24 13:57:12 2014 \"CTLR VER 1.2\"\n\r
process-ioc:47630 Wed Sep 24 13:57:12 2014 2014/09/24 13:57:09.588 ctlr asynOctetB\
ase interrupt
process-ioc:47630 Wed Sep 24 13:57:12 2014 2014/09/24 13:57:09.588 ctlr read
process-ioc:47630 Wed Sep 24 13:57:12 2014 $\n\r
Later the IOC sent the escape character but received no reply, instead we logged this:
process-ioc:47630 Wed Sep 24 15:39:47 2014 2014/09/24 15:39:45.586 ctlr wrote
process-ioc:47630 Wed Sep 24 15:39:47 2014 \033\r
process-ioc:47630 Wed Sep 24 15:39:57 2014 2014/09/24 15:39:51.839 Can't connect \
to 192.168.0.129:4003: Connection refused ctlr -1 autoConnect could not connect
process-ioc:47630 Wed Sep 24 15:40:12 2014 2014/09/24 15:40:07.228 Can't connect \
process-ioc:47630 Wed Sep 24 15:40:17 2014 2014/09/24 15:40:13.228 Can't connect \
process-ioc:47630 Wed Sep 24 15:40:37 2014 2014/09/24 15:40:35.882 Can't connect \
process-ioc:47630 Wed Sep 24 15:41:12 2014 2014/09/24 15:41:10.316 Can't connect \
The IOC continued to send escapes and then it apparently reconnected;
we logged this:
process-ioc:47630 Wed Sep 24 15:41:22 2014 2014/09/24 15:41:19.259 ctlr wrote
process-ioc:47630 Wed Sep 24 15:41:22 2014 \033\r
... etc., same as normal interaction above ...
Meanwhile, on the IOC, iocsh printed this:
2014/09/24 15:39:48.034 ctlr Ctlr:Reset: connection closed in read
2014/09/24 15:39:48.034 ctlr Ctlr:Reset: I/O error after reading 0 bytes: ""
2014/09/24 15:39:48.034 ctlr Ctlr:Reset: Protocol aborted
2014/09/24 15:40:06.828 ctlr Ctlr:Reset: pasynCommon->connect() failed: Can't connect to 192.168.0.129:4003: Connection refused
2014/09/24 15:40:06.828 ctlr Ctlr:Reset: Protocol aborted
2014/09/24 15:40:33.093 ctlr Ctlr:Reset: pasynCommon->connect() failed: Can't connect to 192.168.0.129:4003: Connection refused
2014/09/24 15:40:33.093 ctlr Ctlr:Reset: Protocol aborted
Here is the line in st.cmd that configures asyn for this controller
drvAsynIPPortConfigure ("ctlr", "192.168.0.129:4003",0,0)
Here are the records in the database. Processing Ctlr:Reset invokes
the reset protocol in ctlr.proto.
record(asyn, "Ctlr:Asyn"){
field(PORT, "ctlr") # must match port in drvAsynIPPortConfigure
# let ADDR, OMAX, IMAX fields default to 0
record(stringin, "Ctlr:Reset") {
field(SCAN, "Passive")
field(DTYP, "stream")
field(INP, "@ctlr.proto reset ctlr") # out ESC CR, in to stringin VAL
field(PINI, "1") # force reset at startup
field(FLNK, "Ctlr:ResetCalc") # set Ctlr intlk if reset fails
Here is the reset protocol in ctlr.proto etc., which sends the reset
command to the controller and collects the response.
OutTerminator = CR;
InTerminator = LF CR;
ExtraInput = Error;
ReplyTimeout = 5000;
ReadTimeout = 5000;
# 'in' is the entire expected banner string
# so any other string will raise @mismatch exception
reset {
out ESC; # just ESC is the reset command
in '"CTLR VER 1.2"'; # banner then LF CR
in '$'; # $ then LF CR completion sequence
exec "dbpf Process:Phase.VAL 0"; # Phase PV indicates Reset was processed
Here at the commands to create the asyn log shown above
asynSetTraceIOMask("ctlr",0,0x2)
asynSetTraceFile("ctlr",0)
The log messages are sent from the IOC to an iocLogServer running on a
different Linux host, which writes them to a file.
- RE: Asyn disconnects, reconnects to serial device server Mark Rivers
Re: EDM Michael Westfall
<2014>
2025
2026
Training and pre-meetings at the upcoming EPICS meeting at SACLAY Dalesio, Leo
<2014>
2025
2026
