1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fanout to Sub Records in a Different IOC Causes Core Dump
To: "Poff, Mark A" <[email protected]>
Date: Tue, 7 Oct 2014 20:16:18 +0000
On Oct 7, 2014, at 3:55 PM, Poff, Mark A <[email protected]> wrote:
> As an alternate we tried placing the fanout record in the Processing IOC, but that also core’d.
Since the processing IOC core dumps regardless of where you are running the fanout record, I suspect the bug is more likely to be found in your Process routine rather then in the IOC code. Have you looked at the core dump to see where the crash is occurring? If you replace your processing routine with something really simple, do you still get the crash?
Steven Hartman
[email protected]
RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
Prev: RE: Fanout to Sub Records in a Different IOC Causes Core Dump Mark Rivers
Next: stumbled at the first softioc example HaveF
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Fanout to Sub Records in a Different IOC Causes Core Dump Poff, Mark A
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
