1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PROC vs PROC_HOST
To: <[email protected]>
Date: Wed, 8 Oct 2014 06:46:49 -0400
UNRESTRICTED | ILLIMITÉ
Ran into a problem when trying to cross-compile an EPICS application for the ARM architecture under a Linux x86_64 host.  My build created both the x86 and x86_64 binary, but would not create the ARM.  I eventually change the application makefile:
PROC_HOST = myApplication
to
PROC = myApplication
This caused ARM version to compile, but it failed due to missing libraries in the base, specifically asHost and dbStaticHost.  Looking at the makefile for those library, I noticed that it had
LIBRARY_HOST = dbStaticHost
and
LIBRARY_HOST = asHost
These are the only two libraries from the EPICS base I found that define the target using the LIBRARY_HOST (macro?) instead of LIBRARY.
I changed both of these to LIBRARY, recompiled the EPICS based, then successfully recompiled the ARM version of my application.
Is there a reason why these two libraries are defined as LIBRARY_HOST instead of just LIBRARY?
Re: PROC vs PROC_HOST Andrew Johnson
Prev: Job Opening at Helmholtz-Zentrum Berlin (HZB) Joachim Rahn
Next: Re: stumbled at the first softioc example Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: PROC vs PROC_HOST Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
