1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: could it possible to get pv from another subnet?
To: "'HaveF'" <[email protected]>, <[email protected]>
Date: Tue, 14 Oct 2014 08:27:02 -0500
The network topology is set up so that you *DON"T* normally have any sort of
interaction between the 2 . . . . so why now do you need interaction between
the 2?  What is so important that the camonitor system has to stay on that
subnet instead of being put onto the other one?
This is like that example of having the client in Germany and the server
system being in California.  The question isn't really HOW to do it . . .
the better question is WHY do you want to do it this way  . . . .and just
having the answer being "that's how everything is current working now"
doesn't mean that it has to stay that way.
-----Original Message-----
On Behalf Of Mark Rivers
Sent: Tuesday, October 14, 2014 7:48 AM
To: HaveF; [email protected]
I understand now, the CA client and CA server are on separate non-routeable
subnets.  In that case I am not sure how to do it, though it seems like it
could be done with port forwarding.  Router A could forward packets on a
particular port (e.g. 15605) to port 5065 on the CAS machine.  Then the
camonitor machine would need to change the ports it uses for CA to those new
ports.
behalf of HaveF [[email protected]]
Sent: Tuesday, October 14, 2014 2:45 AM
To: [email protected]
Subject: could it possible to get pv from another subnet?
Hi, all,
My network's topology is like this:
              router A                          router B
           | 202.201.1.4 |                   | 202.201.1.5 |
       | 192.168.1.200 |                     | 192.168.1.100 |
       |   CAS         |                     |   camonitor   |
Could it possible to get pv from another subnet?
Could it possible to Set the CAS's EPICS_CA_ADDR_LIST to 202.201.1.5, and
then configure router B, map the port 5065 to
192.168.1.255:5065<http://192.168.1.255:5065>?
or I have to replan the whole net and use layer 3 switch to connect the
subset?
                    |    layer 3 switch            |
       | 192.168.1.200 |                     | 192.168.2.100 |
       |   CAS         |                     |   camonitor   |
Thanks for reading.
Sincerely,
HaveF
Re: could it possible to get pv from another subnet? Hartman, Steven M.
could it possible to get pv from another subnet? HaveF
RE: could it possible to get pv from another subnet? Mark Rivers
Prev: RE: could it possible to get pv from another subnet? Mark Rivers
Next: how to add a variable in asyn command 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: could it possible to get pv from another subnet? Hartman, Steven M.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
