1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree
To: Heinz Junkes <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 15 Oct 2014 15:59:33 -0500
On 10/15/14 3:44 PM, Heinz Junkes wrote:
> _xmlFree can be found in /opt/local/libxml2.dylib
> 00000000000f2b28 D _xmlFree
> Pointing LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to this dir will not
> solve the problem:
> LD_LIBRARY_PATH=/opt/local/lib
> DYLD_LIBRARY_PATH=/opt/local/lib
> Any idea?
Hi, Heinz.
Did you build from source, or are you using the pre-built binary
version?  If you're using the pre-built binary, then there is likely
something wrong with it since it should include any libraries it needs.
Moving beyond that, you said the symbol _xmlFree can be found in
/opt/local/libxml2.dylib, but then you set LD_LIBRARY_PATH and
DYLD_LIBRARY_PATH to /opt/local/lib.  Note that the path ends in a
directory named "lib".  If the libxml2.dylib library is in /opt/local,
then you'd need to set LD_LIBRARY_PATH and DYLD_LIBRARY_PATH to
/opt/local, not /opt/local/lib.
Lewis
Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
Prev: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
Next: Support for hivolt power supply Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
