1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Support for hivolt power supply
To: [email protected]
Date: Thu, 16 Oct 2014 07:23:17 +0200
Dear Emma,
these are ISEG power supplys. Depending on the interface type (USB, Serial or
CAN bus), you need different methodes to access them. For the USB interface,
you just need an protocol file for the streamdev suppoprt of the asyn driver,
for the serial interface you need to use an asynPortDriver, due to the very
slow speed of the interface. For the CAN bus you need a special interface from
PEAK, as the ISEG CAN bus devices are hard to get working with other CAN
interfaces.
For the USB or the serial interface I can send you my code which supports the
full functionality. Note that these devices do not have internal ramping, so
this has to be done via sequenzers on the IOC side, if needed, which I do not
have yet.
Jörn
Am Mittwoch, 15. Oktober 2014, 22:09:56 schrieb Emma Shepherd:
> Hi all,
> We need to develop EPICS support for a hivolt.de T1CP power supply.  So here
> comes the usual question - has anybody by any chance already done this?
> Cheers,
> Emma
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Support for hivolt power supply Emma Shepherd
Prev: Re: EPICS on vxWorks Andrew Johnson
Next: Re: areadetector, iocSimDetector can not be started on OS X due to dyld: Symbol not found: _xmlFree Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Support for hivolt power supply Emma Shepherd
Next: Usage of the dbNameToAddr funciton ZHANG Zhaohong
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
