1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: webopi -- http status 404 error
Date: Thu, 16 Oct 2014 14:00:45 -0400
Hello,
I am trying to setup a webopi on Debian 7.6 following the instructions:
http://htmlpreview.github.io/?https://github.com/ControlSystemStudio/cs-studio/blob/master/applications/plugins/org.csstudio.opibuilder.rap/html/WebOPI.html
After I installed tomcat7, I can see the tomcat7 works:
However, I can't make the webopi works.  Here is what I got:
The steps I took are:
1. Download webopi.war from
http://ics-web.sns.ornl.gov/css/products.html
2. cp webopi.war /var/lib/tomcat7/webapps/apps#webopi.war
3. chown tomcat7.tomcat7 /var/lib/tomcat7/webapps/apps#webopi.war
4. In /var/lib/tomcat7/conf/catalina.properties, add line at the end of the file:
org.csstudio.rap.preference=/home/tom/css-workspace/css_rap.ini
5. create and edit: /home/tom/css-workspace/css_rap.ini.  I comment out most of the options in the instructions and only have the following left:
#---------------EPICS configuration-----------------------
org.csstudio.platform.libs.epics/auto_addr_list=false
org.csstudio.platform.libs.epics/use_pure_java=true
org.csstudio.platform.libs.epics/addr_list=127.0.0.1 192.168.1.2
org.csstudio.platform.libs.epics/max_array_bytes=160000
#---------------WebOPI configuration----------------------
org.csstudio.opibuilder/opi_repository=/home/tom/css-workspace/CSS
org.csstudio.opibuilder/startup_opi=Top.opi
org.csstudio.opibuilder/mobile_startup_opi=Top.opi
org.csstudio.opibuilder/color_file=color.def
org.csstudio.opibuilder/font_file=font.def
And when I used the following url
http://192.168.2.57:8080/apps/webopi
or
http://localhost:8080/app/webopi
I got the http 404 status error (webopi resource not available) error.
Please help me on this.  I don't know which step is wrong.  I also tries to download webopi3.3.war and got the similar error.
I noticed in the webopi download page, the redhat liniux is supported.  Can webopi run on Debian also ?  My java version is "1.6.0_32".
Thank you so much,
-Tom
Re: webopi -- http status 404 error Kasemir, Kay
Prev: Re: StreamDevice "in" command disturbed by out command Dirk Zimoch
Next: Re: webopi -- http status 404 error Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice "in" command disturbed by out command haquin
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
