On 10/15/2014 7:11 AM, Florian Feldbauer wrote:
Is it possible (e.g. during initialization) to set the DRVH fields via
the asynPortDriver?
At present asynPortDriver does not set DRVH or DRVL. However, I think
this would be a good addition, and easy to add. AsynPortDriver already
has a getBounds function. If you write your writeInt32 function
correctly, you can have it coerce the value to be within range, and get
the same functionality. Unfortunately, the VAL field of the EPICS
channel won't be coerced so users won't know its happening without a
separate readback channel (but you won't write out of range values to
hardware). The initAi and initAo functions already call getBounds, and
convertAi and convertAo use these limits to calculate eslo and eoff. I
see no reason why initLo and InitAo couldn't be modified to adjust DRVH
and DRVL to these values (i.e. set them if they are both 0, or adjust
them if the current values are out of range). Certainly, one would want
to allow the database to specify a tighter range than device support
permits.
Also, you can probably use less than 17 records for the workaround
others were suggesting if you use a couple of dfanout records.
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
- Re: AsynPortDriver setting DRVH of ao? Florian Feldbauer
- AsynPortDriver setting DRVH of ao? Florian Feldbauer
asyndriver : Multiple drvAsynIPPort Patel Jignesh
Re: Interface Labview and EPICS Olivier Zimmermann
<2014>
2025
2026
<2014>
2025
2026
