1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Possible to close a TCP/IP socket in asyn?
To: Mark Rivers <[email protected]>, "'[email protected]'" <[email protected]>
Date: Thu, 23 Oct 2014 13:29:38 +0100
On 22/10/14 21:51, Mark Rivers wrote:
Hi Adam,
I have tried disconnecting the asyn port and asynManager's freeAsynUser.
A frequent source of confusion is that the word "disconnect" is used in 2 completely different contexts in asyn.  The first is asynManager::disconnect, the second is asynCommon::disconnect.
This is the documentation for pasynManager->disconnect
Disconnect the asynUser from the port,addr to which it is connected via a previous call to connectDevice. The call will fail if the asynUser is queued or locked, or has a callback registered via exceptionCallbackAdd.  Note that asynManager:disconnect and asynCommon:disconnect are completely different.
Disconnect from the hardware device or communication path. The queueRequest must specify priority asynQueuePriorityConnect.
You said you "tried disconnecting the asyn port" and that did not work.  I suspect that perhaps you called pasynManager::disconnect?  All that does is to remove the association of that asynUser structure with a particular port and address.  It does not cause the underlying device to be disconnected from asyn, e.g. closing a socket.  The reason is simple: there could be many such asynUser structures associated with that port,addr.  This provides a way to re-use the asynUser structure to be connected to another port and address.
asynCommon::disconnect causes the port to be disconnected from the device itself, e.g. to close the socket.
____________________________________
Thanks Mark, that certainly clarifies the situation however if I use asynCommonSyncIO::disconnectDevice (the documentation says this calls asynCommon::disconnect) the socket still shows up as "ESTABLISHED" in netstat, at least with 4-22. Am I missing some incantation? I am unclear what should go in drvPvt if I am to use asynCommon::disconnect directly.
Adam.
Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Possible to close a TCP/IP socket in asyn? Adam Bark
RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
Prev: Re: PV monitoring and email reporting tool Johnson, Andrew N.
Next: Re: Possible to close a TCP/IP socket in asyn? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Possible to close a TCP/IP socket in asyn? Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
