1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: galil softIOC lose the galil controller
To: Heinz Junkes <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Thu, 30 Oct 2014 08:47:47 +0000
Hi Heinz,
Please follow this setup procedure for the RIO PLC.
1.  Use GalilTools to set the IP address
2.  Record the MAC address of the RIO
3.  Edit /etc/rc.d/rc.local and add the following:
# Add multicast route for Galil hardware
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
# Add arp entry for Galil RIO device
arp -s <IPADDRESS> <MACADDRESS>
4.  Reboot softIOC or type above commands as root, then exit root login
5.  Telnet into RIO from softIOC, and issue the following commands
:IB1   (Possibly IK1 on some firmware)
:BN   (Burn the changes)
:^M
exit
6.  From now on only hosts with the arp entry can telnet into RIO
Then try the IOC again.  I recommend using a single IOC and connection to the RIO.
Also try the email again.
Best wishes,
Mark.
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Mail: [email protected]
Sent: Thursday, 30 October 2014 19:16
To: Mark Clift
Cc: [email protected] ([email protected])
Subject: Re: galil softIOC lose the galil controller
Hi techtalk,
we are running two galil RIO-47120 controllers. We are using the newest versions of galilsuite and galiltools on debian linux.
ii  galilsuite                          1.0.2                               amd64        Test GalilSuite build
ii  galiltools                          1.6.3                               amd64        GalilTools
and the Galil-3-0 motorapp.
We could'nt get them running stable. Until the day before yesterday I connected to both controllers with one softioc. About every second week they stopped working and the controllers could'nt be ping-ed anymore. We have to reset the controllers. Both stopped at the same time.
Now I run two softioc's on the same Unix-System. Each of them opens a connection to a single controller ... now they sopped working after about 5-6 hours.
And again both of them at the same time. I have no info's in any log-file.
The program on the IOC is very simple:
dmc-file, rioDIag.dmc :
'Galil Motion Control [email protected]
'http://www.galilmc.com/
#epics
'Insert code to run on
' GalilStartController() here...
MA 141,14,141,214;
MD [email protected];
MS [email protected];
WT 100
XQ#update,1;'spawn update thread
EN
#update;'Example update loop
AT0
epics[0]=TIME;'time tick
epics[1]=_OP0
epics[2]=_TI0
OPepics[9]
IF (epics[10])
SB8
WT50
CB8
epics[10]=0
ENDIF
AT200;'see SCAN field in
' galil_array_access.substitutions
JP#update
#CMDERR;'runs if an error occurs
MG "An error occured at line",_ED
TC 1;'print type of error info
ZS;'Remove returns from callbck
EN;'End execution
#TCPERR
MG {M} "TCPERR.  Dropped handle", _IA4
RE
started with this cmd-file, rioDiag.cmd:
#Galil Motion Control [email protected] http://www.galilmc.com/
#Load Galil Data Record Support
#dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_motor.substitutions")
#Provide access to Galil Array Table
dbLoadTemplate("$(TOP)/GalilDiagApp/Db/rioDiag_array_access.substitutions")
# GalilCreateController command parameters are:
# 1. Const char *portName - The name of the asyn port to be created for this controller
# 2. Const char *address  - The address of the controller
# 3. int numAxes          - The number of axis that will be used on the controller
# 4. double updatePeriod  - The time in ms between datarecords
#   (See controller's DR command for minimum).
#   Async if controller + bus supports it, otherwise is polled/synchronous.
GalilCreateController("rioDiag", "10.0.0.210", 1, 32)
#GalilCreateController("rioDiag", "141.14.128.41", 2, 8)
# GalilCreateAxis command parameters are:
# 1. char *portName Asyn port for controller
# 2. char axis A-H,
GalilCreateAxis("rioDiag","A")
#GalilCreateAxis("rioDiag","B")
#GalilCreateAxis("Galil","C")
#GalilCreateAxis("Galil","D")
#GalilCreateAxis("Galil","E")
#GalilCreateAxis("Galil","F")
#GalilCreateAxis("Galil","G")
#GalilCreateAxis("Galil","H")
# GalilStartController command parameters are:
# 2. char *code file to deliver to the controller, "" for none.
# 3. char *label to execute on file, "" to not execute.
GalilStartController("rioDiag", "rioDiag.dmc", "#epics")
and this st.cmd:
#!../../bin/linux-x86_64/GalilDiagApp
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","IOCRIODIAG")
epicsEnvSet("TOP","/srv/ioc/sys/$(IOC)")
#epicsEnvSet("SUPPORT","/home/epics/EPICS/support")
#epicsEnvSet("EPICS_BASE","/home/epics/EPICS/base")
#epicsEnvSet("ASYN","/home/epics/EPICS/support/asyn/asyn4-22")
#epicsEnvSet("MOTOR","/home/epics/EPICS/support/motor/motorR6-8")
epicsEnvSet("DISPLAY",":0")
epicsEnvSet("LOG_DIR", "/srv/ioc/log")
dbLoadDatabase("$(TOP)/dbd/GalilDiagApp.dbd",0,0)
GalilDiagApp_registerRecordDeviceDriver(pdbbase)
# Configure an example controller
#< rioMezz.cmd
< rioDiag.cmd
#dbLoadRecords ("$(TOP)/db/rioMezz.db","P=FHIFEL:,R=HELPER:,S=GUNRELAY:")
dbLoadRecords("$(TOP)/db/attenuator.db","P=FHIFEL:,R=DIAG:,S=ATTENUATOR:")
dbLoadRecords("$(TOP)/db/flipper.db","P=FHIFEL:,R=DIAG:,S=FLIP:")
#dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioMezz:")
dbLoadRecords("$(TOP)/db/checkAlive.db","RIO=rioDiag:")
## autoSaveRestore setup
save_restoreSet_Debug(0)
# status-PV prefix, so save_restore can find its status PV's.
save_restoreSet_status_prefix("${IOC}:")
# ok to restore a save set that had missing values (no CA connection to PV)?
# ok to save a file if some CA connections are bad?
save_restoreSet_IncompleteSetsOk(1)
#In the restore operation, a copy of the save file will be written.  The
# file name can look like "auto_settings.sav.bu", and be overwritten every
# reboot, or it can look like "auto_settings.sav_020306-083522" (this is what
# is meant by a dated backup file) and every reboot will write a new copy.
save_restoreSet_DatedBackupFiles(1)
# specify where save files should go
set_savefile_path("/srv/ioc/log/as","/save")
# specify where request files can be found
set_requestfile_path("/srv/ioc/log/as","/req")
# Specify what save files should be restored when.
# Up to eight files can be specified for each pass.
set_pass0_restoreFile("${IOC}_0.sav")
set_pass1_restoreFile("${IOC}_1.sav")
# Number of sequenced backup files (e.g., 'auto_settings.sav0') to write
save_restoreSet_NumSeqFiles(3)
save_restoreSet_SeqPeriodInSeconds(600)
# Time between failed .sav-file write and the retry.
save_restoreSet_RetrySeconds(60)
iocInit()
makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_0.req", "autosaveFields_pass0")
makeAutosaveFileFromDbInfo("/srv/ioc/log/as/req/${IOC}_1.req", "autosaveFields_pass1")
create_monitor_set("${IOC}_0.req", 5, "P=${IOC}:")
create_monitor_set("${IOC}_1.req", 30, "P=${IOC}:")
## Report Installed and Configured I/O-Hardware Information
dbior 0 1 > ${LOG_DIR}/Database/${IOC}.dbior
dbhcr     > ${LOG_DIR}/Database/${IOC}.dbhcr
dbl       > ${LOG_DIR}/Database/${IOC}.dbl
By the way, the mail-sending on RIO works only once or twice .. then it stops sending any mails
Best regards,
Heinz
On 30.10.2014, at 01:17, Mark Clift <[email protected]> wrote:
> Hi Qingru,
> I would guess that the multi-cast route is missing, which is required for the Galil driver you're using.
> We add the following line into /etc/rc.local
> The error simply says it could not poll the first 8 digital inputs with Galil TI (Tell input) command.
> Also there is a newer Galil driver designed to replace the one your using located here:
> http://motorapp.github.io/Galil-3-0/
> Best wishes,
> Mark
> Dr. Mark Clift
> 800 Blackburn Road
> Clayton 3168
> Ph: +613 8540 4264
> Fax: +613 8540 4200
Re: galil softIOC lose the galil controller Heinz Junkes
Re: galil softIOC lose the galil controller Pearson, Matthew R.
galil softIOC lose the galil controller Mark Clift
Prev: Re: galil softIOC lose the galil controller Heinz Junkes
Next: areaDetector 2.0 on windows xp 32bit Zunbeltz Izaola
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: galil softIOC lose the galil controller Heinz Junkes
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
