Hi Izaola,
It looks like perhaps you have some commands in the wrong order in your st.cmd file. The first command in st.cmd should be "<envPaths", but from your output it appears that the dbLoadRecords commands are before the <envPaths command. It also looks like you are running iocInit twice? Please look at the example in iocBoot/iocRoper/st.cmd to see the correct order of the commands.
For the medm problem, are you sure that you installed the 32-bit version of the EPICS Windows Tools, and not the 64-bit version by mistake?
From: [email protected] [[email protected]] on behalf of Zunbeltz Izaola [[email protected]]
Sent: Thursday, October 30, 2014 4:36 AM
To: [email protected]
Subject: areaDetector 2.0 on windows xp 32bit
Dear all,
I have installed the prebuild binaries of areaDetector (ADroper driver)
for windows 32bit.
I installed medm from the EPICS windows tools (medm.exe is on the windows
PATH) and the cygwin/X windows server.
I run xterm from the cygwin XLauncher (local) and move to the folder with
start_epics.bat file.
When running this file I have two problems
1) MEDM is no staring. I have and error windows with the message that
medm.exe is not a valid win32 application.
2) The ioc starts but with lots of error messages that I don't understand
(output of termimal below)
Can anyone point to me where can be the errors?
Thanks in advance for the help
C:\base-3.14.12.4\support\areaDetector-2-0\ADRoper\iocs\roperIOC\iocBoot\iocRoper1>..\..\bin\win32-x86\roperApp
st.cmd
macLib: macro ADCORE is undefined (expanding string
dbLoadRecords("$(ADCORE)/db/ADBase.template",
"P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1"))
dbLoadRecords("$(ADCORE)/db/NDFile.template",
macLib: macro ADROPER is undefined (expanding string
dbLoadRecords("$(ADROPER)/db/roper.template",
dbLoadRecords("$(ADCORE)/db/NDPluginBase.template","P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),NDARRAY_ADDR=0"))
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template",
"P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int16,FTVL=SHORT,NELEMENTS=1500000"))
macLib: macro ADCORE is undefined (expanding string <
$(ADCORE)/iocBoot/commonPlugins.cmd)
set_requestfile_path("$(ADROPER)/roperApp/Db"))
Starting iocInit
save_restore:readReqFile: unable to open file ADBase_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDFile_settings.req. Exiting.
save_restore:readReqFile: unable to open file roper_settings.req. Exiting.
save_restore:readReqFile: unable to open file NDPluginBase_settings.req.
Exiting.
save_restore:readReqFile: unable to open file NDStdArrays_settings.req.
Exiting.
save_restore:readReqFile: unable to open file commonPlugin_settings.req.
Exiting.
auto_settings.sav: 0 of 0 PV's connected
< envPaths
epicsEnvSet("ARCH","win32-x86")
epicsEnvSet("IOC","iocPVCam1")
epicsEnvSet("TOP","C:/base-3.14.12.4/support/areaDetector-2-0/ADRoper/iocs/roperIOC")
epicsEnvSet("SUPPORT","","C:/base-3.14.12.4/support")
epicsEnvSet("ASYN","C:/base-3.14.12.4/support/asyn-4-22")
epicsEnvSet("CALC","C:/base-3.14.12.4/support/calc-3-2")
epicsEnvSet("BUSY","C:/base-3.14.12.4/support/synApps_5_7/support/busy-1-6")
epicsEnvSet("SSCAN","C:/base-3.14.12.4/support/sscan-2-9")
epicsEnvSet("AUTOSAVE","C:/base-3.14.12.4/support/synApps_5_7/support/autosave-5-1")
epicsEnvSet("AREA_DETECTOR","C:/base-3.14.12.4/support/areaDetector-2-0")
epicsEnvSet("EPICS_BASE","C:/base-3.14.12.4")
errlogInit(20000)
dbLoadDatabase("C:/base-3.14.12.4/support/areaDetector-2-0/ADRoper/iocs/roperIOC/dbd/roperApp.dbd")
roperApp_registerRecordDeviceDriver(pdbbase)
Warning: IOC is booting with TOP =
but was built with TOP =
"J:/epics/devel-AD2.0/areaDetector/ADRoper/iocs/roperIOC"
epicsEnvSet("PREFIX", "13ROPER1:")
epicsEnvSet("PORT", "ROPER1")
epicsEnvSet("QSIZE", "20")
epicsEnvSet("XSIZE", "1396")
epicsEnvSet("YSIZE", "1040")
epicsEnvSet("NCHANS", "2048")
roperConfig("ROPER1", 0, 0)
asynSetTraceIOMask("ROPER1",0,2)
#asynSetTraceMask("$(PORT)",0,9)
# Create a standard arrays plugin, set it to get data from the Roper driver.
NDStdArraysConfigure("Image1", 5, 0, "ROPER1", 0, 0)
# Load all other plugins using commonPlugins.cmd
iocInit()
## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$
## EPICS Base built Sep 18 2013
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=13ROPER1:")
epics> save_restore:write_save_file: Backup file (auto_settings.savB) bad
or not found. Writing a new one. [141030-103703]
- areaDetector 2.0 on windows xp 32bit Zunbeltz Izaola
Re: galil softIOC lose the galil controller Heinz Junkes
<2014>
2025
2026
asynError IOC Message Patel Jignesh
<2014>
2025
2026
