1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Disable database question
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 30 Oct 2014 19:01:50 +0100
This would still disable all records individually, not the IOC database processing as a whole.
It also blocks "regular" usage of DISL fields of all your records, which might not be acceptable in your application.
If you want to completely pause your IOC (including Channel Access server and client), the function or iocShell command
   iocPause
might be what you are looking for.
Calling
   iocRun
later on should bring a paused IOC back to life.
Note that these calls are not widely and frequently used, so there might still be side effects that we are not aware of. (But would definitely want to know about!)
Good luck,
~Ralph
On 30/10/2014 18:24, Dalesio, Leo wrote:
Put the DISL of every PV to point to one PV - and put a button on just that one. I think that there is mention of this in the Record Reference Manual and/or the Application Developer's Guide.
Bob
From: [email protected] [[email protected]] on behalf of Elmer Pensack [[email protected]]
Sent: Thursday, October 30, 2014 12:48 PM
To: [email protected]
Subject: Disable database question
Hi All,
This may sound like an odd request, but is there a way to stop processing all PVs in the database? I know I can stop processing individual PVs using  the DISV field, but I was wondering if there was a way to stop processing the whole database at once without looping through every PV.
Thanks in advance for any suggestions.
Elmer Pensack
Disable database question Elmer Pensack
RE: Disable database question Dalesio, Leo
Prev: Re: Disable database question Andrew Johnson
Next: RE: Disable database question Zelazny, Michael Stanley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Disable database question Dalesio, Leo
Next: Re: Disable database question Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
