1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: devAsynFloat64::initCommon findInterface asynFloat64Type
To: "Mark Rivers" <[email protected]>, <[email protected]>
Date: Fri, 31 Oct 2014 17:35:45 -0000
Hi Mark,
Attached.
Cheers,
Peter.
Sent: 31 October 2014 17:22
To: Heesterman, Peter; [email protected]
Please send the complete output when the IOC starts up.  Also send the output of the command
asynReport 10
From: Heesterman, Peter J [mailto:[email protected]]
Sent: Friday, October 31, 2014 12:07 PM
To: Mark Rivers; [email protected]
Hi Mark,
Here is this constructor (unashamedly copied from your TestAsynPortDriver class):
CLeyboldTurboPortDriver::CLeyboldTurboPortDriver(const char *AsynPortName)
   : asynPortDriver(AsynPortName,
                    1, /* maxAddr */
                    NUM_PARAMS,
                    asynInt8ArrayMask | asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface mask */
                    asynInt8ArrayMask | asynInt32Mask | asynFloat64Mask | asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
                    0, /* asynFlags.  This driver does not block and it is not multi-device, so flag is 0 */
                    1, /* Autoconnect */
                    0, /* Default priority */
                    0) /* Default stack size*/
Cheers,
Peter.
Sent: 31 October 2014 17:04
I suspect that in the constructor for your driver you did not set the asynFloat64Mask bit in the interfaceMask argument to the asynPortDriver constructor.  If your driver will do callbacks on the asynFloat64 interface you also need to set that bit in the interruptMask argument to the asynPortDriver constructor.
From: [email protected] [mailto:[email protected]] On Behalf Of Heesterman, Peter J
Sent: Friday, October 31, 2014 11:57 AM
To: [email protected]
Subject: devAsynFloat64::initCommon findInterface asynFloat64Type
Hi all,
I’m developing a device that needs to read out a floating point value that forms part of a 24-byte structure read from the serial port.
I’m doing this as an AsynPortDriver device.
I get the above error on my record definition, but I’m not sure why.
I’m still new as an EPICS user, so my question is: can you give me some advice as to what I’m missing?
Many thanks,
Peter.
Attachment: LeyboldTurbo.log
Description: LeyboldTurbo.log
RE: devAsynFloat64::initCommon findInterface asynFloat64Type Mark Rivers
Re: devAsynFloat64::initCommon findInterface asynFloat64Type Pearson, Matthew R.
devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
RE: devAsynFloat64::initCommon findInterface asynFloat64Type Heesterman, Peter J
Prev: RE: devAsynFloat64::initCommon findInterface asynFloat64Type Mark Rivers
Next: RE: devAsynFloat64::initCommon findInterface asynFloat64Type Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
