1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NaN and analog records
To: EPICS tech-talk <[email protected]>
Date: Tue, 4 Nov 2014 13:32:30 +0100
Hi Everybody,
another problem is that DRVL and DRVH seem to be ignored for NaN.
The following record;
record(ao,"UE56ID3R:BaseParGapTrs") {
    field(ASG,"USERCTL")
    field(DRVH,"0.1")
    field(DRVL,"0")
    field(LINR,"NO CONVERSION")
    field(OIF,"Full")
    field(PREC,"4")
for example can be set to NaN (at least for Epics Base 3.14.8).
We also found that you can type "NaN" at any entry field in DM2K which
writes NaN directly to the PV.
Greetings
  Goetz Pfeiffer
On 11/04/2014 11:21 AM, Benjamin Franksen wrote:
> Hi Everyone
> how do you handle a client writing NaN to an analog record (which
> probably happens by accident)? My intuition tells me that the proper
> response for the record is to go into an INVALID status, but apparently
> this is not what happens by default...
> The problem with accepting NaN is that subsequent tests (e.g. via calc
> or sub record) may give wrong results, perhaps leading to motors
> starting to move when they should not (it happened to us, which is the
> reason why I write this).
> Cheers
> Ben
> "Make it so they have to reboot after every typo." ― Scott Adams
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Attachment: signature.asc
Description: OpenPGP digital signature
Re: NaN and analog records Ralph Lange
NaN and analog records Benjamin Franksen
Prev: Re: compiling issues during building cothread Adam Bark
Next: Re: NaN and analog records Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: NaN and analog records Benjamin Franksen
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
