1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Sequencer: are variables shared?
To: [email protected]
Date: Tue, 04 Nov 2014 19:11:14 +0100
I' trying to spawn a set of instances of a sequencer program from ioc
shell, the program is like this:
program myProgram
int myVar;
assign myVar to "myPv{n}";
monitor myVar;
ss mySs {
Different input pvs are assigned to different program instances:
epics> seq myProgram "n=_1"
epics> seq myProgram "n=_2"
epics> seq myProgram "n=_n"
The problem is that the several instances seem to interfere each other,
I tried to print the address of the input variable (myVar) and I noticed
that they share the same myVar!!!
I've tried to move the myVar's definition inside the state set but the
problem persists.
Is there a way to work around this problem, or must I run my sequencers
as stand-alone applications?
Thanks in advance
Damiano
Re: Sequencer: are variables shared? Andrew Johnson
Prev: Re: NaN and analog records Andrew Johnson
Next: Re: Sequencer: are variables shared? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: support for NIKHEF Hall probes Pierrick Hanlet
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
