1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MinGW PRODDIR_LDFLAGS
Date: Tue, 4 Nov 2014 20:42:29 +0000
When attempting to build EPICS Base 3.14.12.4 for win32-x86-mingw, the build fails when attempting to build antelope.exe due to ld being unable to find the Com library it had just built a few lines earlier.
The problem is that the library load path flag ends up as -L/c/Path_to_Base_Libs rather than -Lc:/Path_to_Base_Libs. If I change to the right directory and run the failed command with the correct path, the command then succeeds.
I did some preliminary work in trying to track down where the /c/ was coming from, but the build system is large and full of variables. PRODDIR_LDFLAGS appears to be the variable that contains the non-working path. But trying to trace that back, I only found directory paths that are set relative to EPICS_BASE, which is set to C:/Correct_Path. Can anyone with a better knowledge of the EPICS build system than I point me to the issue?
As well, to make sure that my issue isn't with my setup, I have MinGW, gnuwin32, and Strawberry Perl installed and my path is set up in the following order:
%REGULAR_PATH%;
%PATH_TO_MINGW_BIN%;
%PATH_TO_MSYS_BIN%;
%PATH_TO_GNUWIN32_BIN%;
%PATHS_TO_PERL_BINS%
Re: MinGW PRODDIR_LDFLAGS Andrew Johnson
Prev: Re: Sequencer: are variables shared? Andrew Johnson
Next: Compiling SDDS problem Chen Xue
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer: are variables shared? Damiano Bortolato
Next: Re: MinGW PRODDIR_LDFLAGS Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
