1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to perform Loop in VDCT
To: priya tiwari <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 13 Nov 2014 17:22:26 +0000
Hi Priya,
I would do this with a subroutine record or an SNL program.  Yes, you can make loops in EPICS database, but I would not implement your example in that way.
If I had to do this kind of stuff in a database - for example, if I had to be able to write the _expression_ at run time - I'd use an acalcout record, and part of the _expression_ for your example would look like this:
sum(100*(ix%2)[0,9])+sum(-100*(!(ix%2))[0,9])
where, for example
    ix is (0,1,2,3,...)
    ix%2 is (0,1,0,1,...)
    ix[0,9] is (0,1,2,3,4,5,6,7,8,9,0,0,0,...)
If you're really desperate for an explicit loop, the acalcout and scalcout records have the "until" function:
    a:=0;b:=0;k:=until(a:=a+1.3;b:=b+1;b>=9);a
which is arcane, and difficult, and merely implements this:
    a=0;
    for (b=0; b<10; b+=1) {
        a += 1.3;
If you want to process records in a loop, on the other hand, I second Bob's advice, and note that the calcout record has more help for conditionally executing a link.  Finally, the sscan record does loops, and I've used it with calc records to make 2D arrays of sample data.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of priya tiwari [[email protected]]
Sent: Thursday, November 13, 2014 12:51 AM
To: [email protected]
Subject: How to perform Loop in VDCT
How to perform "for loop" in VDCT?
I want to try this  program in VDCT .
float avg;
int sum=0;int i,j;
for (i=0;i<20;i++)
for(j=0;j<10;j++)
if(j%2==0)
sum=sum+100;
else
diff=-100;
avg=(sum+diff)/10;
printf("%f",avg);
what type of record and field is used for this program in VDCT?
please provide me solution?
Thanks in advance......
How to perform Loop in VDCT priya tiwari
Prev: RE: autosave fdbrestore Mooney, Tim M.
Next: Re: Agilent 3458A Multimeter Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How to perform Loop in VDCT Dalesio, Leo
Next: autosave fdbrestore Pearson, Matthew R.
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
