Dear Qingru,
Thank you for the update. It's interesting that a managed switch seems to have fixed the problem.
I hope the RIO is still functioning ok now?
What model, and firmware RIO do you have?
Best wishes,
Mark.
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Hi Mark,
Thanks for your suggestion!
I checked the linux with “route –n” command, and the IP address of the galil was in it.
I changed the unmanaged switch with a managed switch, and the galil softIOC ran a long time without any errors.
Qingru Mi
Sent: Thursday, October 30, 2014 8:17 AM
Subject: galil softIOC lose the galil controller
Hi Qingru,
I would guess that the multi-cast route is missing, which is required for the Galil driver you're using.
We add the following line into /etc/rc.local
route add -net 224.0.0.0 netmask 240.0.0.0 dev eth0
The error simply says it could not poll the first 8 digital inputs with Galil TI (Tell input) command.
Also there is a newer Galil driver designed to replace the one your using located here:
http://motorapp.github.io/Galil-3-0/
Best wishes,
Dr. Mark Clift
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
- galil softIOC lose the galil controller Mark Clift
- Re: galil softIOC lose the galil controller Mi Qingru
how to execute 'mcaget/mcaopen/...' command on IOCSHELL JaeRyong Seo
Re: how to execute 'mcaget/mcaopen/...' command on IOCSHELL Eric Norum
<2014>
2025
2026
DG 645 burst mode Prerana Kankiya
<2014>
2025
2026
ANJ, 17 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
