1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: usage of CALC
To: <[email protected]>
Date: Fri, 28 Nov 2014 09:56:25 +0100
Hello Liang,
I would not use a calcout record. Use an ao record and scale the value using .ASLO. So the VAL field of the ao record can hols user coordinates (mm) abd the value sent to the device will be VAL/ASLO. Sthus you need to set ASLO to 0.05 (1/20).
Dirk
On 27.11.2014 15:52, 梁雅翔 wrote:
     Sorry to bother you, I have some trouble which pullze me some time, could you please give me some advice.
     I am trying to control a step motor.
     Now I want to set a number(60) to pv(um distance), send the number*20(60*20=1200) to device. I think CALC would be useful. I could not understand CALC well though I have RRM 3-14.
     The following code is what I do.
Thanks!
*******devKohzuAries.db
record(longin,"RPS")  # send to device
     field(DESC, "move relativly")
     field(DTYP, "stream")
     field(INP,  "@devKohzuAries.proto RPS $(PORT) $(A)")
     field(FLNK,"um distance")
record(calcout,"um distance")
     field(DTYP,"stream")
     field(OUT,"@devKohzuAries.proto RPS $(PORT) $(A)")
     field(CALC,"A*20")
     field(INPA,"um distance.VAL")
********  devKohzuAries.proto
RPS{
     out "\x02RPS1/5/%d/0";
Liang YX
Institute of High Energy Physics
Chinese Academy of Sciences
P. O. Box 918, 100049 Beijing
R. P. China
Tel: 0086-0188235977-603
Email: [email protected]
usage of CALC 梁雅翔
Prev: Re: Defining enums to express state? Torsten Bögershausen
Next: RE: edm questions Linda.Pratt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: usage of CALC Ralph Lange
Next: Sorenson SGA DC power supplies Linda.Pratt
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
