1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input?
To: <[email protected]>, <[email protected]>
Date: Fri, 28 Nov 2014 13:09:38 +0000
Hi Peter,
This is possible (the motor record is a good example), but it needs the record type to support it. Most record types don’t support two way communication with device support.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
From: Heesterman, Peter J [mailto:[email protected]]
Sent: 28 November 2014 11:38
To: [email protected]
Subject: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input?
I’d like to be able to use an output record in this way, if possible, but my tests show that it doesn’t work.
From code comments like:
/* This code is for I/O Intr scanned output records, which are not tested yet. */
I suspect that I’m asking for a feature/behaviour that isn’t implemented, or is at any rate not commissioned.
An example of the usage I’ve been looking for:
It is possible for the software user to switch the equipment off by means of a caput (or similar) command.
But, it is also possible for the equipment user to switch the equipment off physically.
In which case, this is detected by the software, and can be detected by the software user through a caget (or similar), of the same record.
It would be possible to use two different records for this purpose, of course.
Many thanks,
Peter.
Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Ralph Lange
Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Heesterman, Peter J
Prev: Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Ralph Lange
Next: RE: edm questions Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Is it possible for an Asyn output record to be, also, an (I/O Intr - driven) input? Ralph Lange
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
