1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm questions
To: Mark Rivers <[email protected]>, "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 30 Nov 2014 18:39:21 +0000
Yes, the fonts come from exceed. The missing text is probably the result of the objects in question being motif widgets which have their own font requirements.
From: "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>>
Date: Friday, November 28, 2014 at 9:34 AM
To: "'[email protected]<mailto:'[email protected]>'" <[email protected]<mailto:[email protected]>>, aps <[email protected]<mailto:[email protected]>>
Subject: RE: edm questions
Thanks for the response to my edm question.
I should have said in my original post that I am running edm on a Fedora 15 Linux system, but I am displaying on a Windows 7 machine running Exceed 14 as the X11 server.  So the fonts come from Exceed, correct?
Since edm reports that it did successfully replace the missing arial fonts with my system default helvetica fonts, is the fact that my button and menu widgets have no text at all on them likely to be a font problem or something else?  Note that the menu widgets do display text for the dropdown list, but the currently selected item does not display its text.
From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of [email protected]<mailto:[email protected]>
Sent: Friday, November 28, 2014 4:21 AM
To: [email protected]<mailto:[email protected]>
Mark,
Attachments of DLS colours and fonts, the result of running the file and asking EDM to view the font mappings on my RHEL6 and RHEL5 and a snapshot of part of the screen as it is intended to look in editing and run modes (PVs all disconnected though).
We mostly have RHEL6 in production use.
Linda
Software Systems Engineer
Controls Department
+44 (0)1235 778058
www.diamond.ac.uk
Diamond Light Source Ltd
Sent: 26 November 2014 22:01
Hi Mark,
This sounds like a font problem.    I'm on vacation today
and need to get back to some furniture moving, but I'm attaching
a copy of our fonts.list and colors.list files so you have some
more examples to work from.    The colors are probably fine
with the default, but fonts can be tricky depending on your
linux distribution.    The attached ones work for us from RHEL5,
RHEL6, and from windows systems.
Edm widget layouts assume a standard dpi, so you should use
either 75dpi or 100dpi fonts exclusively in your fonts.list file.
I think the default is 75dpi, which is what we're using.
You should install xorg-x11-fonts-75dpi, or the xorg-x11-fonts-100dpi
depending on which way you go.   You should also install xorg-x11-fonts-misc
and xorg-x11-fonts-truetype as well.
If you're still having trouble, post a copy of your fonts.list file and
any console error msgs and I'll take a look later.
Cheers,
- Bruce
On 11/26/2014 1:25 PM, Mark Rivers wrote:
Folks,
I am new to edm and am having problems with fonts or colors or something.
The problem is that all of the buttons in the edm display appear to be lacking labels and the text entry widgets have no text.  I have attached a screen shot of the edm display showing the problem.
Is this due to the font errors, or a color problem, or something else?
When I run an edm display from Diamond Light Source I get the following errors repeating from edm in a message window:
Cannot find font: [arial-bold-r-10.0]
  Using default window font: [arial-bold-r-12.0]
Cannot find default window font: [arial-bold-r-12.0]
  Using default site font: [helvetica-medium-r-10.0]
It appears that it did find my default site font, helvetica-medium-r-10.0.
Here are the arial fonts on my system:
corvette:aravisGigEApp/op/edl>xlsfonts | grep arial
--arial-bold-i---0-0-0-0-p-0-iso8859-1
--arial-bold-r---0-0-0-0-p-0-iso8859-1
--arial-medium-i---0-0-0-0-p-0-iso8859-1
--arial-medium-r---0-0-0-0-p-0-iso8859-1
-monotype-arial-bold-i-normal--0-0-0-0-p-0-iso8859-1
-monotype-arial-bold-i-normal--0-0-100-100-p-0-iso8859-1
-monotype-arial-bold-i-normal--0-0-75-75-p-0-iso8859-1
-monotype-arial-bold-r-normal--0-0-0-0-p-0-iso8859-1
-monotype-arial-bold-r-normal--0-0-100-100-p-0-iso8859-1
-monotype-arial-bold-r-normal--0-0-75-75-p-0-iso8859-1
-monotype-arial-medium-i-normal--0-0-0-0-p-0-iso8859-1
-monotype-arial-medium-i-normal--0-0-100-100-p-0-iso8859-1
-monotype-arial-medium-i-normal--0-0-75-75-p-0-iso8859-1
-monotype-arial-medium-r-normal--0-0-0-0-p-0-iso8859-1
-monotype-arial-medium-r-normal--0-0-100-100-p-0-iso8859-1
-monotype-arial-medium-r-normal--0-0-75-75-p-0-iso8859-1
I added those fonts to my fonts.list, but I still get the same errors.
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
RE: edm questions Mark Rivers
Re: edm questions Bruce Hill
RE: edm questions Linda.Pratt
Prev: RE: Photonic Science X-Ray sCMOS camera system tom.cobb
Next: Does EPICS has defects? HaveF
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: edm questions Mark Rivers
Next: RE: edm questions Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
