$ which xsubpp
/opt/local/bin/xsubpp
Of course reordering the $PATH also fix the problem.
I am sorry for hijacking this email thread.
> On 02 Dec 2014, at 09:50, Torsten Bögershausen <[email protected]> wrote:
> What does
> which xsubpp
> give on your system ?
> Mac OS X 10.9 has this:
> /usr/bin/xsubpp
> (And I have perl from /usr/bin/perl):
> which perl
> /usr/bin/perl
> Does it help to adjust your $PATH to use perl from /usr/bin ?
> On 02/12/14 09:14, Wang Xiaoqiang (PSI) wrote:
>> Hi,
>> Unfortunately Perl failed when building 3.15.1 on OS X Yosemite, with PERL 5.16.3 installed by MacPorts,
>> $ which perl
>> /opt/local/bin/perl
>> $ $ perl -V:bin
>> bin='/opt/local/bin';
>> The xsubpp program should be /opt/local/bin/xsubpp.
>> $ ls -l /opt/local/bin/xsubpp*
>> lrwxr-xr-x 1 root admin 11 Oct 18 22:41 /opt/local/bin/xsubpp -> xsubpp-5.16
>> -rwxr-xr-x 1 root admin 4576 Oct 18 22:40 /opt/local/bin/xsubpp-5.16
>> This creates the following warning,
>> $ perl -CSD /usr/bin/xsubpp -typemap /opt/local/lib/perl5/5.16.3/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
>> perl version 5.16.3 can't run /usr/bin/xsubpp. Try the alternative(s):
>> /usr/bin/xsubpp5.16 (uses perl 5.16)
>> /usr/bin/xsubpp5.18 (uses perl 5.18)
>> Run "man perl" for more information about multiple version support in
>> Mac OS X.
>> Maybe one should not hardcode perl’s binary path, but derive it from perl config:
>> PERLBIN = $(shell $(PERL) ../perlConfig.pl bin)
>> XSUBPP = $(firstword $(wildcard $(PERLBIN)/xsubpp $(EXTUTILS)/xsubpp))
>> This fixes my problem.
>> Best
>> Xiaoqiang
>>> On 01 Dec 2014, at 19:22, Andrew Johnson <[email protected]> wrote:
>>> Thanks guys. I committed Michael's version and added a patch to the
>>> 3.14.12 Known Problems page.
>>> In RHEL 6 /usr/share/perl5/Extutils/xsubpp exists as a soft-link to
>>> /usr/bin/xsubpp, while earlier Perl versions have it only in Perl's
>>> ExtUtils directory.
>>> - Andrew
>>> On 12/01/2014 07:23 AM, Michael Davidsaver wrote:
>>>> A more (OS) portable way to accomplish this
>>>> XSUBPP = $(firstword $(wildcard /usr/bin/xsubpp $(EXTUTILS)/xsubpp))
>>>> On 12/01/2014 05:43 AM, Torsten Bögershausen wrote:
>>>>> Hi,
>>>>> I tried to compile EPICS under "Scientific Linux release 7.0 (Nitrogen)"
>>>>> It failed, because xsubpp is no longer here:
>>>>> but found here:
>>>>> /usr/bin/xsubpp
>>>>> Thanks to Götz, who helped me debugging the error and finding a fix.
>>>>> For now I added a shell script to see where xsubpp is.
>>>>> The following applies to base-3.15.1-rc1 (but the problem is in older
>>>>> bases as well)
>>>>> Does this sound reasonable, or are there better ways ?
>>>>> diff --git a/src/ca/client/perl/Makefile b/src/ca/client/perl/Makefile
>>>>> index 6ae32dd..516e494 100644
>>>>> --- a/src/ca/client/perl/Makefile
>>>>> +++ b/src/ca/client/perl/Makefile
>>>>> @@ -54,10 +54,11 @@ include $(TOP)/configure/RULES
>>>>> ifdef T_A
>>>>> EXTUTILS = $(shell $(PERL) ../perlConfig.pl privlib)/ExtUtils
>>>>> + XSUBPP = $(shell if test -x /usr/bin/xsubpp ; then echo
>>>>> /usr/bin/xsubpp ; else echo $(EXTUTILS)/xsubpp ; fi)
>>>>> %.c: ../%.xs
>>>>> $(RM) $@ $@_new
>>>>> - $(PERL) $(EXTUTILS)/xsubpp -typemap $(EXTUTILS)/typemap $< >
>>>>> $@_new && $(MV) $@_new $@
>>>>> + $(PERL) $(XSUBPP) -typemap $(EXTUTILS)/typemap $< > $@_new &&
>>>>> $(MV) $@_new $@
>>>>> $(INSTALL_PERL_MODULES)/$(PERL_ARCHPATH)/%: %
>>> People everywhere confuse what they read in newspapers with news.
>>> -- A. J. Liebling
- catools (caget/caput/camonitor) and locale settings from the environment Goetz Pfeiffer
- Re: catools (caget/caput/camonitor) and locale settings from the environment Torsten Bögershausen
- xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
- Re: xsubpp moved under Sscientif Linux 7.0 Michael Davidsaver
- Re: xsubpp moved under Sscientif Linux 7.0 Andrew Johnson
- Re: xsubpp moved under Sscientif Linux 7.0 Wang Xiaoqiang (PSI)
- Re: xsubpp moved under Sscientif Linux 7.0 Torsten Bögershausen
RE: edm questions Mark Rivers
<2014>
2025
2026
<2014>
2025
2026
