1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Area Detector and Andor
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 3 Dec 2014 10:20:08 -0800
Hi Mark,
I returned to our Andor problem and now I mostly understand what is going wrong. It turns out that the libandor.so library which comes with the Area Detector package does not work with our version of the Andor SDK, which is version 2.94. Building Area Detector package puts libandor.so in lib/linux-86_64, the IOC when built, links to the library in Area Detector, and when started, loads this library and the IOC almost works with the exception that no image data are received from the camera. If I remove the libandor.so library from the Area Detector, build my IOC it links to the libandor.so library in the locally installed SDK package. When I start the IOC it loads the SDK library and everything works; the image data are received from the camera.
Presently we have AD version 1.8, 1.9.1, and 2.1 installed. I have modified a Makefile in the andorSupport directory not to install the andor libraries. I am not sure if this is the correct way to deal with our problem.
One more problem remains. This fix works with AD 1.8 and 1.9.1 but not with 2.1. The IOC built with AD 2.1, still exhibits the same problem, all seems to work except for getting the image data. I wonder if there is another level if mismatch between AD 2.1 and our SDK?
Zen
RE: Area Detector and Andor Mark Rivers
Prev: RE: FW: EPICS 3.15.1 Mark Rivers
Next: RE: Area Detector and Andor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Create two channels on same PV name in same CA context? J. Lewis Muir
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
