1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: 3.15.1 DB Build Issue
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 4 Dec 2014 13:42:54 +0000
Andrew,
Changing the template references in the DB Make file from _DEPENDS to _TEMPLATE didn't change a thing about the functions of the make.  I'm not sure it would have made a difference anyway, from the definition in 4.6.10 of the AppDevGuide.
However, I've run across a much more serious issue.
It seems that in my substitutions file, I can only have a single template file referenced.  I have a single substitution file that has sections for ai, ao, bi, and bo records.  All substitution lines in this file seem to use the first template definition file when the substitutions get expanded.
This worked on 3.14.12.4, but doesn't work in the new 3.15.1 software.
Included is the substitution file, and all sections of this file seem to use the first template definition.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7133
Email: [email protected]
-----Original Message-----
Sent: Wednesday, December 03, 2014 6:11 PM
To: Dudley, David
Subject: Re: DB Build Issue
Hi David,
On 12/03/2014 04:52 PM, Dudley, David wrote:
> I'm creating 2 .db files using substitution files and 4-template files
> (ai,ao,bi,bo,...).
> In the Makefile, I have these lines (different because I was trying to
> diagnose what's going on):
quoted text as image, how confusing...
> When I change the first template file template file, both output files
> generate fine.
> When I change any of the other template files, only the second output
> file generates.
> I originally had all the templates on a single line, as in the second
> file definition, but that didn't work either.
> Looking at the definition in 4.6.10, it seems that perhaps I shouldn't
> be able to define more than one template file anyway????
> Ideas would be appreciated.
Shouldn't those variables be spelled _TEMPLATE, not _DEPENDS?
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Attachment: BACNet_SRF.substitutions
Description: BACNet_SRF.substitutions
Prev: Re: FW: EPICS 3.15.1 Ralph Lange
Next: RE: FW: EPICS 3.15.1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: connecting EPICS to a Beckhoff PLC ronaldo.mercado
Next: RE: 3.15.1 DB Build Issue Dudley, David
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
