1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: read status nin "" 0 error with
To: Ana Malagon <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 10 Dec 2014 14:12:42 -0800
Did you change the -1 to 19 in the asynSetTraceIOMask command too?  I don’t see actual I/O values shown in the output below.
On Dec 10, 2014, at 1:32 PM, Ana Malagon <[email protected]> wrote:
Changing -1 to 19 works, as does moving the TraceMask line below iocInit, thanks!
I realized that I had set respond2Writes incorrectly (it was 0, now have it set to -1). Changing this removes the "read status "" nin 0" error, however I still only get back 0 when I try to query the frequency. From the log messages, it seems like it's reading 14 characters though?
I suspect you’re getting some additional characters in front of the actual value which is breaking your atof().  Getting the asynSetTraceIOMask right will show this.
If that’s the case then switching from atof() to sscanf() is probably the easiest thing to do.
At first glance I don't see anything pointing to an error in these messages, unless it's the timeout message, which occurs for both Get and Set. Eric, I'm not quite sure how to set the flags in prologixGPIBConfigure?
prologixGPIBConfigure("L0", "10.95.101.74:1234”, 0, 2)
But the low-level stuff seems right, so you might want to just get the asynSetTraceIOMask set properly and see what’s going in and out.
Output messages from ioc below:
## Start any sequence programs
#seq sncxxx,"user=admxHost"
epics> 2014/12/10 13:11:11.704 L0 19 prologixRead 7 EOM:0x6
2014/12/10 13:11:11.704 SDCARLO:GET:POW gpibRead nchars 7
2014/12/10 13:11:11.704 asynManager::portThread port=L0 callback
2014/12/10 13:11:11.704 SDCARLO:GET:ON_OFF queueCallback
2014/12/10 13:11:11.704 SDCARLO:GET:ON_OFF prepareToRead
2014/12/10 13:11:11.704 L0 19 prologixWrite
2014/12/10 13:11:11.705 SDCARLO:GET:ON_OFF writeIt
2014/12/10 13:11:11.818 L0 19 prologixRead 1 EOM:0x6
2014/12/10 13:11:11.818 SDCARLO:GET:ON_OFF gpibRead nchars 1
2014/12/10 13:11:11.818 asynManager::portThread port=L0 callback
2014/12/10 13:11:11.818 SDCARLO:IDN queueCallback
2014/12/10 13:11:11.818 SDCARLO:IDN prepareToRead
2014/12/10 13:11:11.818 L0 19 prologixWrite
2014/12/10 13:11:11.818 SDCARLO:IDN writeIt
2014/12/10 13:11:11.930 L0 19 prologixRead 43 EOM:0x6
2014/12/10 13:11:11.930 SDCARLO:IDN gpibRead nchars 43
epics> dbpr SDCARLO:GET:FREQ
ASG:                DESC: Query Frequency ouput MHz         DISA: 0
DISP: 0             DISV: 1             NAME: SDCARLO:GET:FREQ
RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM      SVAL: 0
TPRO: 0             VAL: 0
epics> dbpf SDCARLO:SET:FREQ 112014/12/10 13:11:54.927 SDCARLO:SET:FREQ queueWriteRequest
2014/12/10 13:11:54.927 L0 addr 19 queueRequest priority 2 not lockHolder
2014/12/10 13:11:54.927 L0 schedule queueRequest timeout
2014/12/10 13:11:54.927 asynManager::portThread port=L0 callback
2014/12/10 13:11:54.927 SDCARLO:SET:FREQ queueCallback
DBR_DOUBLE:         11
epics> 2014/12/10 13:11:54.927 SDCARLO:SET:FREQ gpibWrite
2014/12/10 13:11:54.927 SDCARLO:SET:FREQ writeMsgDouble
2014/12/10 13:11:54.927 L0 19 prologixWrite
2014/12/10 13:11:54.927 SDCARLO:SET:FREQ writeIt
2014/12/10 13:11:54.927 SDCARLO:GET:FREQ queueReadRequest
2014/12/10 13:11:54.927 SDCARLO:GET:FREQ queueCallback
2014/12/10 13:11:54.927 SDCARLO:GET:FREQ prepareToRead
2014/12/10 13:11:54.927 SDCARLO:GET:FREQ writeIt
2014/12/10 13:11:55.080 L0 19 prologixRead 14 EOM:0x6
2014/12/10 13:11:55.080 SDCARLO:GET:FREQ gpibRead nchars 14
TPRO: 0             VAL: 0
On Wed, Dec 10, 2014 at 12:47 PM, Eric Norum <[email protected]> wrote:
Would changing the -1 to 19 in the existing commands in the existing location work, too?
On Dec 10, 2014, at 12:42 PM, Mark Rivers <[email protected]> wrote:
WARNING: At least one of the links in the message below goes to an IP address (e.g.10.1.1.1), which could be malicious. To learn how to protect yourself, please go here: https://commons.lbl.gov/x/_591B
> I’m at a loss then.  I have no idea why enabling ASYN diagnostic messages is having no effect.
I know why it is happening.  Ana is doing this before iocInit.
asynSetTraceMask("L0", -1, 0xFF)
The problem is that using the address of -1 on asynSetTraceMask set the trace mask of all device address that are currently connected to that asyn port.  However, at that point the GPIB device at address 19 has not yet been connected, so its asynTraceMask does not get set.
The solution is to move that line to after iocInit.  You won’t see any trace information that should happen as part of iocInit, but you will see everything after that command is issued.
We might want to change the way asynSetTraceMask($(PORT), -1, MASK) works to avoid this confusion.  Someone else ran into this a couple of weeks ago.
Eric Norum
[email protected]
Eric Norum
[email protected]
read status nin "" 0 error with Ana Malagon
Re: read status nin "" 0 error with Eric Norum
Re: read status nin "" 0 error with Ana Malagon
RE: read status nin "" 0 error with Mark Rivers
Prev: Re: read status nin "" 0 error with Ana Malagon
Next: dxp R3-4 released Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: read status nin "" 0 error with Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
