1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Different behavior on dbdToRecordTypeH - include guard
To: Andrew Johnson <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Wed, 10 Dec 2014 23:26:05 +0000
Hi Andrew,
Thank you for your concern.
Some of my DBD files which define new record type, have the include statements to bring other DBD files (netsting other DBD).
Usually, the nesting DBD has new menu types.
Previous tool puts the include guard for each "typedef" statements, but the new one doesn't do.
It brings me duplicated declaration issue when I try to compile existing code for the new epics base.
I can change my side to avoid it, but we also need to think about backward compatibility.
Please, let me know your opinion.
Thank you.
Best regards,
Kukhee
Kukhee Kim
SLAC National Accelerator Laboratory
2575 Sand Hill Rd, MS 64
Menlo Park, CA 94025
Email: [email protected]
Phone: (650)926-4912
Fax:   (650)926-3800
-----Original Message-----
Sent: Wednesday, December 10, 2014 2:27 PM
To: Kim, Kukhee; [email protected] Talk
Subject: Re: Different behavior on dbdToRecordTypeH - include guard
Hi Kukhee,
On 12/10/2014 02:03 PM, Kim, Kukhee wrote:
> I just found that the tool "dbdToRecordTypeH" in base-R3.15 behaves
> differently compare to the previous version.
> In the previous version, the tool put "include guard" for type
> definition.
> But, the new one doesn't put the "include guard".
The generated files from a 3.15 build do have an include guard, the name it uses has changed slightly though and the guard now wraps the whole header file rather than just a part of it:
> /* aiRecord.h generated from aiRecord.dbd */
> #ifndef INC_aiRecord_H
> #define INC_aiRecord_H
> #include "epicsTypes.h"
> } aiFieldIndex;
> #ifdef GEN_SIZE_OFFSET
> #ifdef __cplusplus
> extern "C" {
> #endif
> #include <epicsExport.h>
> #ifdef __cplusplus
> #endif
> #endif /* GEN_SIZE_OFFSET */
> #endif /* INC_aiRecord_H */
In 3.14 the include guard covered the record structure and index definitions but not the GEN_SIZE_OFFSET section:
> #ifndef INCaiH
> #define INCaiH
> #define aiRecordSIMS	81
> #endif /*INCaiH*/
> #ifdef __cplusplus
> extern "C" {
> #endif
> #ifdef __cplusplus
> #endif
> #endif /*GEN_SIZE_OFFSET*/
Only *Record.c files define the GEN_SIZE_OFFSET macro though, and they shouldn't be including other headers that include their own *Record.h file so this change should be transparent.
What does your complicated include setup that this breaks look like?
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Re: Different behavior on dbdToRecordTypeH - include guard Andrew Johnson
Different behavior on dbdToRecordTypeH - include guard Kim, Kukhee
Prev: Re: Different behavior on dbdToRecordTypeH - include guard Andrew Johnson
Next: Darwin SHRLIB_VERSION build error: multiple target patterns J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Different behavior on dbdToRecordTypeH - include guard Andrew Johnson
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
