1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build system EXPAND not working with INC
To: <[email protected]>
Date: Thu, 11 Dec 2014 15:35:50 -0600
Hi Lewis,
On 12/11/2014 11:54 AM, J. Lewis Muir wrote:
> On Darwin, with EPICS Base 3.14.12.4, I'd like to create and install a C
> header file that has some @VAR@ macros expanded using the INC, EXPAND,
> and EXPAND_VARS build system variables as described in the EPICS Base
> 3.14 release notes, but the build fails with the following error:
> make[3]: *** No rule to make target `../O.Common/favorites.h', needed by `inc'.  Stop.
I can get this to work if I replace your:
>      EXPAND_VARS += FAVCOLOR=red
>      EXPAND += favorites.h@
>      INC += favorites.h
with this:
>      INSTALL_INC += $(INSTALL_INCLUDE)/favorites.h
There are some special rules for include files listed in INC which
assume that they will get created in the O.Common build directory
instead of O.$(T_A) if they can't be found in the regular source
directories. Setting INSTALL_INC directly prevents those rules from
being applied.
HTH,
- Andrew
People everywhere confuse what they read in newspapers with news.
-- A. J. Liebling
Build system EXPAND not working with INC J. Lewis Muir
Prev: asyn R4-25 available Mark Rivers
Next: Re: connecting EPICS to a Beckhoff PLC [SEC=UNCLASSIFIED] Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <2014>  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build system EXPAND not working with INC J. Lewis Muir
Next: asyn R4-25 available Mark Rivers
ANJ, 17 Dec 2015 · Home · News · About · Talk · Base · Modules · Extensions ·
